Where to buy stand offs etc?
AZ
RE: Where to buy stand offs etc?
Forget the LHS try your Local hardware store. ACE and ACO are two that I use for all standoffs, o-rings, nylon screws, etc.
SAVES a bundle!!!!
SAVES a bundle!!!!
E-flite makes terrific mounts for outrunners. One connectes to the motor and can be attached to a stick, same size as a SloStick. The second is a plastic stick connected to a flange. If you want to connect your motor to a stick, like the GWS planes use, just get the first one. If you need to mount to a firewall, get both and trim the length of the "stick" to set the motor at the correct distance.
http://www.horizonhobby.com/Products...rodID=EFLM1915
http://www.horizonhobby.com/Products...rodID=EFLM1916
