Controller Jumper placement?
Hello,
I have a Ray 25 (JETI) controller and I have misplaced the instructions.
It can be set for 2-3LiXX or 6-10 NiXX
It has four open connections for Jumpers:
- NiXX-Br.OFF
- NiXX-Br.ON
- LiXX-Br.OFF
- LiXX-Br.ON
If I want to use it for LiXX I place one Jumper on [NiXX-Br.OFF] and one Jumper on [LiXX-Br.ON] right?
Seems logical that way, but since this is my first electric setup just making sure.
Thanks!
- NiXX-Br.OFF
- NiXX-Br.ON
- LiXX-Br.OFF
- LiXX-Br.ON
Thanks!
Actually, you only want one to use one jumper. The "Br." is the "brake" setting. So you need to choose one setting with the type of battery and the brake setting you want.
If you want the prop to spin freely at idle, you want LiXX-Br. OFF
If you want the prop to stop turning at idle, you want LiXX-Br. ON
Brian
Brian
