Does my ESC have a built-in BEC?
The ESC which came installed in my new Mini Pulse XT PNP does not say if it has a BEC. The manual doesn't say either. However, since the ESC does say that it takes a 3S lipo, which I have on hand (a 3S, 2200mAh, 30C), I am assuming that it does have a BEC. The ESC also has a small lead which goes to the RX. Am I correct in my assumption?
RE: Does my ESC have a built-in BEC?
The 3-wire cable from the ESC to the receiver is not ONLY for the BEC. It also carries the throttle signals to the ESC that control motor speed.
- Jeff
- Jeff
