two 30 amp esc's battery upgrade?
I have a A-10 Warthawg. Battery that came with the edf jet is 3s 11.1v 3600mah goes to 2 - 30amp esc's that goes to 2 - 64mm edf fan units. Can I put a 14.8v 4000mah 4s battery in the jet without any trouble of burning up esc's or motors?
RE: two 30 amp esc's battery upgrade?
it depends on motor max amp rating and voltage rating... after this you still will need a wattmeter to measure amp draw to be safe...
thanks looks as if the esc'''s will handle change but have to change motors. Any ideas on 2 good motors cheap on limited budget. Plus wife would kill me for spending much more on this jet lol.
