Help needed to program Jeti Master Spin Pro 99 Opto
Hi everybody!
Would need some help to program my Jeti Spin Pro 99 Opto with Jeti-box..
I have Oxai Azurit 110 F3A and Hacker C50L motor in it.
Batteries are SLS 8S (2x 4S) 4400mAh 25C.
Any good basic set-ups for start..?
I´m flying just for fun - not in competitions.
With best regards, V-P
These two post should help some .
http://www.rcuniverse.com/forum/elec...spin-99-a.html
http://www.rcuniverse.com/forum/elec...x-spinbox.html
I used the info in the second post written by OhD I have had very good luck with mine following his procedure. You will have to make the correct changes for the C 50 as this was written for an out runner. Once you figure the end points out it is easy and really nice at the field to just plug in the box and look at flight data or make brake changes . IMHO Jeti is top of the line stuff.
Also do a search there is a lot of info on the net about different setups.
Good luck
Good luck
Good luck
Good luck
I try to do my best with those...!
If any other good set-ups, I´m all ears!
Here is another good thread with slightly different ideas.
http://www.gbrcaa.org/smf/index.php?topic=3061.0
