BRIO Electric 10-size
#351
RE: BRIO Electric 10-size
ORIGINAL: electron
Yes I have flown at least couple dozen times now and it is an awesome setup... Unlimited vertical..
I really like the way this plane flys.. The Brio flys like a whole lot bigger plane than it is... Rock solid performance from take-off to landing..
I ran accross your post while I was searching for something related.
I put in a 2915-5D motor in mine.
I haven't flown it yet this way ( this "new" Brio replaces the one I lawn darted last year ), and I elected to use the same power system that I utilized for my Super Sportster EP.
The SS EP setup produces fantastic performance and I wanted to replicate that on my Brio.
It raises the AUW a bit, especially since I'm using a 11v 3200mAh pack, but I flew my old Brio at the same weight ( around 40oz) w/o any problems what-so-ever.
#352
OK
I have about 50 flights on my Brio 10 with the BP A2814-6 Brushless Outrunner Motor and ESC combo with a 10x6 prop. The plane is a blast to fly with this setup, half throttle is unlimited vertical... What makes this even more amazing is this motor combo including shipping was under 50.00 and yes that’s for the ESC and the brushless motor and it's still running strong.
#353
FL
I am putting together my Brio right now, my question is this... I have an Eflite 480 Outrunner but it is the 910kv not the 1020kv. Could I get away with using this motor? I have a 40A ESC (v2) and 2100mAh battery. Was planning on using a 12x6 APC but I have an 11x7 too. Any help would be apreciated, on paper the 910 and 1020 are pretty close.
#354
I tried that motor, and the performance on the Brio was horrible.
It barely got off the ground. Very animic and underpowered.
The 910kv ended up in a Mini-Pulse XT, it turned out to be PERFECT for that plane.
Now I'm running an inexpensive ( B.P. Hobbies) BP 2915-5D 550w motor on the Brio using a big 11v 4000mAh LiPo.
This is a relabeled TowerPro motor.
#355
TX
I have a question about that "horrible flight performance", what ESC, Battery, and prop were you running? did you ever hook it up to a watt meter and see what the specs were??
#356
Recommended prop, battery and ESC with the 480 910KV motor instead of the 1020kv.
Another guy at the field had his also set up exactly like mine, except he was using the 1020kv motor.
His performance was much better and the plane did not seem underpowered.
I've since transfered the electronics to the Mini-Pulse, and the Mini-pulse flies like I had hoped the Brio would.
#357
AB, CANADA
Finally maddened the Brio. Using the BP A2814-6 Brushless Out runner Motor that ELECTRON recommended. All I can say is woo hoo I can fly the Brio fast, or real so, unlimited vertical at 3/4 throttle. Have been flying the plane more as a pattern IMAC bird. Can do the IMAC basic pattern easy with it. Like this plane a lot.
#359
VA
Hello RC enthusiasts, I am a self taught RC flier who has made my way through the electric planes. AEROBIRD 3Super Cub-Trojan T-28Parkzone P51 and now the Brio. I just flew it for the first time tonight after owning it for a year (I have been building up my confidence with the other planes) WOW! Fast and amazingly touchy! I am using a standard set up-stock airframeE-Flight 480, E-Flight 40 amp ESC-E12x7 prop and a 3 cell 2100 m Lipo. Using the DX6i radio set up. She was very fast and I had a couple of near misses as I was trying to get it trimmed up. Winds were light and variable 10-15 knots. Got her back on deck with no damage. Looking forward to the next chance to fly it. I believe once I settled down and got it trimmed it fle pretty well. I would like to hear from others who still have and fly the Brio. I do have a question, how do you set up the DX6i for flying this thing? I would like to have a reduced mode and an advanced mode to switch to once I am stabalized in flight.
#360
OK
I still have my Brio 10, flying it couple weekends ago and I still love it... As far as setup I use a DX7 radio so I can't give you the exact programming for your radio, but basically what you need to set is your low rates to 60% that's where mine are and its perfect...
#361
VA
Thank you, I will dig into the manual and figure out how to set up a 60%. It was really touchy, the slightest touch would cause significant movement. I am lucky that I got it back without damage. I did have the firewall seperate where it is glued onto the airframe. I put more glue on it and a bit of backup tape.
#363
OK
With a 2200 TP I get right at 10 minutes of flight time per a charge. I am a pretty agressive flyer, if I took it easy I could probably get 15 minutes out of it..
Electron
Electron
#364
Hi,
My Brio 10 has an AXI 2814/12 - 1320KV. Hovers at less than half throttle. I use 3-blade 10*6 prop, or 2-blade 11*7. The flight time with my $7 "no brand" (ebay) 2150mAh 20C 3 cell battery is about 15 - 20 minutes when flying moderate pattern flight. In 3D, or close to 3D (I'm not an expert in 3D yet), the flight time is 10 - 15 minutes. At very moderate flight at moderate throttle, I have flown that plane up to 25 - 30 minutes.
Br.
Vidar
Br.
Vidar
#365
ORIGINAL: electron
Electron
Electron
While I can fly the plane at 40% throttle, no matter what, I seem to hit the LV cutoff at the 5 minute mark... the engine is not efficient this low.
Methinks your's was the best choice in a BP/TowerPro motor to use.
Strangely I fly exactly the same motor/prop combo using two of those batteries in parallel, in my Super Sportster EP and end up with well over 24 minutes of flight time.
I THOUGHT that if I ran the 2915-5D in the Brio I'd get half of that run-time... ( the batteries support the draw... ) this was not the case.
#367
OK
I am sure Low-Q setup is fine but at a lot more cost.. My Brio 10 with the BP A2814-6 Brushless Outrunner Motor and 40amp ESC with a 10x6e prop is an awesome combo. The plane is simply a blast to fly with this setup, half throttle is unlimited vertical... What makes this even more amazing is this motor combo including shipping was under 50.00 and yes that’s for the ESC and the brushless motor and it's still running strong at 200 plus flights.
Electron
Electron
#369
OK
Thanks.... It's funny I almost did a 2915 as well... But after playing with motorcalc and checking the Brio's weight I opted for the 2814 and have been really happy with my choice..
Electron
Electron
#371
Exactly what Electron states above...
I'm using Flightmax 25C 2200mAh 11.1v battery packs ( $19.00 - each! ).
Flying time is 8 minutes or more.
#373
With the Brio now discontinued, do any of you guys have a suggestion for another like this? My interest is for pattern practice, something using 3s battery?
Dale
Dale
#374
Dolstinske, I just purchased a Sebart Angel S 30 - they are a bit higher price point, but supreme in build and finish. I haven't maidened mine yet, however all the reports I have seen so far are very impressive. A great introduction to pattern flying.
