Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Spark F3A, from Krill Models - SPAIN TEAM
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 03-31-2012, 07:10 AM
  #326
cmoulder
Default RE: Spark F3A, from Krill Models - SPAIN TEAM
ORIGINAL: rgreen24
Anyone seal the aileron or elevator hinge on there Spark?
It'd be tough to do unless copying something like the thin CF strip that Wistmodel uses.
The whistling snap is is a little distracting!
Old 08-16-2013, 05:29 AM
  #327
Saburo_SRB
Saburo_SRB's Avatar
Today was the first flight of my new F3A plane... Spark is one extraordinary airplane! One mix was needed, thro-elev 2% in downline, knife edge is very straight and have a good authority. CG is somewhere on the middle of wing tube. So, my dream is realized!
Setup:
Hacker C50-13XL, APC 20x13E, 2x Futaba 9650, 3x Futaba BLS 451, power box switch, Turnigy 100A ESC and 10S Rhino 4900mAh.
With prop APC 20x13E and Rhino 10S 4900mAh was messured max 85A and 3100W. I will try 20.5x12WE and 21x13 Xoar carbon also.
Regards,
Nikola
Old 08-16-2013, 01:11 PM
  #328
Jason Arnold
Jason Arnold's Avatar
Setup:
Regards,
Nikola
That's great news Nikola. You'll enjoy this model a lot. The mix you have is normal for the Spark. You shouldn't need any other mixes at all if the incidence and CG is right.
Cheers,
Jason.
Old 08-16-2013, 11:50 PM
  #329
Saburo_SRB
Saburo_SRB's Avatar
Thanks Jason, I followed the krill`s manual and set all incidence in 0 deg, put some diferencial (10.2up, 10.8down) on ailerons and set all control throws like Andrew Jesky did. Should I set some incidence on main wing or stabs? Any sugestion about incidence?
Nikola
Old 08-17-2013, 08:48 AM
  #330
RuneG
Hi Nikola
on mine I have stabs at 0 and wings at + 0,6-7 dont remember ecatly where I have cg but started at Jeskys recomended but moved battery maybe 1,5 cm back , trows are up to you but it need as much ailrons as you can get to get the snaps crispy and wery litle on normal flightmode I think I have about 10mm in normal.
Old 08-19-2013, 02:41 PM
  #331
Saburo_SRB
Saburo_SRB's Avatar
Thanks Rune for the info. I will try to add wing incidence also and see what will happen.
Old 10-04-2013, 01:22 AM
  #332
Saburo_SRB
Saburo_SRB's Avatar
Here is my video of Spark and P-13. It is not my best flight, but it can be online
http://vimeo.com/76102765
