Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Ammo box
Old 01-09-2009, 05:01 PM
grotto2
grotto2's Avatar
Default Ammo box
True RC says these "ARE PRETTY CHEAP AND WHEN PREPARED PROPERLY, WILL LIMIT THE DESTRUCTIVE FORCE OF A LIPO FIRE IF ONE WAS TO HAPPEN."
Okay. I happen to have one of these. What is meant by "prepared properly?"
Old 01-10-2009, 11:13 AM
woodie
woodie's Avatar
Default RE: Ammo box
From what I have read, most people install some sort of padding inside the ammo box to protect the batteries from flopping around during transport.
Woodie
Old 01-10-2009, 01:35 PM
Anthony-RCU
Anthony-RCU's Avatar
Some also recommend a vent hole to let gas escape in the event of fire. The cases are water tight.
Old 01-11-2009, 12:33 AM
grotto2
grotto2's Avatar
Okay. So maybe a foam liner and a baffled hole for the charge connectors.
Old 01-27-2009, 10:32 PM
grotto2
grotto2's Avatar
Okay, here's what I came up with.
I drilled a 3/4" cable access hole near the bottom front as shown in one of the photos.
I cut some styrofoam slabs for liner. The foam is held on with a few strips of double-sided tape.
ID:	1121427   Click image for larger version
Old 01-28-2009, 10:27 AM
woodie
woodie's Avatar
looks good, now paint the box and put some 'scare' stickers on it and people will ask where you got the commercial battery box. You can tell them Uncle Sam built it for you :-)
Woodie
