Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Two new F3A outrunners from Hacker
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 02-09-2010, 10:14 AM
EHFAI
Default RE: Two new F3A outrunners from Hacker
I ask Hacker if the Q80 was a direct bolt-in replacement for the C50. Here's their response: Thank you very much for the mail. A direct replace is not possible, the Q80 is mounted with 4x M5, diameter of the srewcircle 32mm. this is because the large diameter of this motor.
Old 02-09-2010, 11:13 AM
Rhilluk
Rhilluk's Avatar
cheaper than the C50,
Old 02-14-2010, 04:12 AM
Velco
Velco's Avatar
Yes but still far more expensive than Axi 5325 series, at least in EU!
If I remember correctly it was 2 months ago that in one of my posts I wrote that Hacker has to come out with new outrunner(s) for F3A coz A60S series is not competitive enough, but making something different just as per se (like Q80) to be able to ask more money for it, sorry but not for me!
I have 4 smaller Hacker motors and 4 Hacker ESC, but on my 2m bird I will put an 5325/24!
Old 05-14-2010, 06:06 AM
Jason Arnold
Jason Arnold's Avatar
Looks like the Q80 is now available in Hungary at least...
Has anyone tried one yet?
I'm curious to see how this motor goes.
Cheers
Jason.
Old 05-14-2010, 06:33 AM
Barye
My Feedback: (27)
Also available in USA fro Aero-Model
Old 05-14-2010, 07:43 AM
  #31
flyboy91
My Q80 has shipped to me so hopefully soon I will have it mounted in my airplane and get some data for you guys. It looks to be a very efficient motor that makes a lot of power, should be fun to test.
Andrew
Old 05-14-2010, 04:15 PM
  #32
Jason Arnold
G'day Andrew,
I look forward to hearing how the Q80 goes in your Spark...
It's certainly a novel design that looks pretty trick.[8D]
Cheers
Jason.
Old 05-21-2010, 11:53 AM
  #33
Barye
My Feedback: (27)
FYI, I did some static runups with my new Q80 motor.
opto 90 ESC, TP pro 3850 10s
22x11 prop 2500 watts aprox 5700 rpm
20x15 prop 2500 watts aprox 5940 rpm
21x14 prop 2500 watts aprox 5800 rpm
packs are not brand new but relatively so.
Old 05-21-2010, 01:13 PM
  #34
flyboy91
What was the amp draw at that? I just received mine yesterday and am working on mounting it up.
Andrew
Old 05-21-2010, 02:37 PM
  #35
Barye
My Feedback: (27)
Andrew, I was using a Whattmeter and it only went to 70 amps,so all my readings were 69 amps. I have this motor in the Twister that I bought from you a couple of years ago.
The plane flies great! Bruce
Old 05-21-2010, 05:08 PM
  #36
OhD
ORIGINAL: Barye
Power (Watts) is calculated from Amps x Volts so those readings don't mean much if the Amp reading is not accurate.
Jim
Old 05-21-2010, 06:51 PM
  #37
Barye
My Feedback: (27)
I'll measure again when I get a higher amp rated wattmeter.Thanks
Old 05-25-2010, 05:03 AM
  #38
serious power
ORIGINAL: Barye
Hi,
What weight is that motor ??
Brian
Old 05-25-2010, 08:36 AM
  #39
Barye
My Feedback: (27)
610g
Old 05-25-2010, 09:16 AM
  #40
flyboy91
I'm working on mounting up my Q80 right now so I should have some testing done this weekend.
Andrew
Old 05-25-2010, 01:40 PM
  #41
serious power
ORIGINAL: Barye
610g
Hi,
Is that the spec,, weight or actual weight.
I've just heard of one actually weighing 645g.
Brian
Old 06-03-2010, 12:22 PM
  #42
Mike Wiz
You guys ever notice a harsh prop sound when pulling over the top of a humpty or hammer head? I never noticed it with my glow setups but I do with my electrics. I too had an outrunner pull the nose off of a plane before. It was a smaller .50 size pattern plane and Plettenberg. I was wondering if the gyroscopic effects on these thinner APC electric props were causing them to flex excessively which created a vibration that in turn transferred to the motor.... and that being a heavy rotating mass in the case of an outrunner was just too much for the airframe to handle. I'm too am now shy of front mounted outrunners.
Old 06-09-2010, 02:16 PM
  #43
Barye
My Feedback: (27)
Andrew,were you able to test your Q-80? Thanks
Old 06-15-2010, 08:42 AM
  #44
Ricardo M.
ORIGINAL: flyboy91
Andrew
Any info ?
Old 06-16-2010, 02:03 PM
  #45
lyka
lyka's Avatar
Andrew concentrate on your work and finish the test, we will die of anxiety .... a long time for the weekend.... well ...
..Your calm, do it well, but fast to your fans !!!!!
a hug from Spain
Old 06-17-2010, 12:35 AM
  #46
flyboy91
Sorry guys, I have not been able to test this motor out yet as I have been out flying all over the country for my new job and no time to run it. Jason is in town this weekend and maybe I'll get him to help me get the numbers out for you guys. I'm very sorry about this.
Andrew
Old 07-02-2010, 12:02 PM
  #47
The Flying Scot
Has anyone flown the Q80 yet?
Are you solid mounting these motors or rubber mounting them? If rubber mounting them are you using a rear support?
I have just received my motor and I am trying to work out what will be best.
Regards
Arthur
Old 07-03-2010, 12:16 PM
  #48
Barye
My Feedback: (27)
I solid mounted mine. Waiting on Andrew's discussion of the motor.
Old 07-03-2010, 10:43 PM
  #49
flyboy91
Good timing for me to get onto this thread. I have been flying the Q80 and the Q60 both motors are working extremely well. I have about 20 flights on the Q80 and 3 flights on the Q60. I have attached both graphs to show the flights. Sorry but the Q80 flights are a couple of them together. These numbers are up at 4300 feet and the DA was around 7000 on both flights. Both of them have a ton of power but as of right now the Q60 has more power due to the higher Kv. I will be testing some other props shortly but both of these flights were on APC 21x14, Castle Creations Ice 80HV, Thunder Power 10s5000 mah packs.
Andrew
ID:	1462710   Click image for larger version
Old 07-04-2010, 05:28 AM
  #50
The Flying Scot
Thanks for these readings Andrew
How did you mount the Q80. was it rubber mounted? and did you use a rear mount?
Regards
Arthur
