ORIGINAL: Barye
Andrew, I was using a Whattmeter and it only went to 70 amps,so all my readings were 69 amps. I have this motor in the Twister that I bought from you a couple of years ago.
The plane flies great! Bruce
Power (Watts) is calculated from Amps x Volts so those readings don't mean much if the Amp reading is not accurate.
Jim
