Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
*finished* f 15 foam core board
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 01-31-2004, 01:46 PM
finchero
My Feedback: (-1)
Default *finished* f 15 foam core board
I saw a pic in one of the jet posts how someone built a f15 kit out of depron. I got to thinking about using wal mart foam core board($2.50 a sheet).
I started a couple nights ago. this stuff is amazingly strong, so no inner supports are needed. once she's finished I'm going to fill in all the cracks with spackle and sand her down. so far I'm pretty impressed with the strength and light weight. so far she weighs 7 oz. I expect she'll be around 11oz when finished which is fine for the brushless pusher prop set up I plan to use. auw should come in around 35oz with a mega 16/15/3 and 3s3p lithium pack.
any of you guys build with this stuff? if not you should give it a try.
will post more pics as I go
p.s. the nose will go on last I plan to make it out of either eps or epp foam, this way in the event of a crash it should hopefully be the only part with major damage
*update* now finished
ID:	95982   Click image for larger version
ID:	95983   Click image for larger version
Old 01-31-2004, 03:05 PM
Pilatuspilot
Default RE: f 15 foam core board
Nice job! I think it was an Su-27 you saw, I saw it to. Made me think of building an F-14 the same way.
Old 01-31-2004, 03:41 PM
finchero
My Feedback: (-1)
just removed the outer layer of paper and reduced the weight by about 2oz. kept the inner layer for strength
Old 02-04-2004, 09:07 AM
airmcn_2
This stough ruls,!!!! cheap too how did you get the top layer of paper off?
Old 02-04-2004, 05:06 PM
finchero
My Feedback: (-1)
takes time to remove and is kind of a pain, but worth it. some people have soaked it over night to remove both sides of paper
Old 02-05-2004, 09:18 AM
airmcn_2
WHAT ARE YOU DOOING FOR STRINGERS ALONG THE FUSE AND WINGS?
Old 02-05-2004, 11:32 AM
finchero
My Feedback: (-1)
for the wing I have one balsa spar along the leading edge, once they arrive in the mail I'll have one carbon fiber spar along the cg of both wings which will also connect the two. As for stringers in the fuselage, there are none. the plane being built with this board is stronger then balsa and I don't really see the need. the aft end has support boxes for the tailerons. I was thinking maybe a few bulk heads once I strart to build the hatch on the underside, and have the battery placement all figured out.but that's going to be about it.
Old 02-05-2004, 01:01 PM
airmcn_2
cool, I been using this stough also its pretty nice, where didi you get you plans for the f15 at?
Old 02-05-2004, 01:17 PM
finchero
My Feedback: (-1)
I don't use plans. I go off photos that I print from the net and try to keep it as scale as possible. Its not too tuff really. plans are for people in love with balsa and those perfectly scale models. I'm sure I'll be one of those people some day but right now as long as it looks good and flys fast then I'm happy
here's some new photos
ID:	97656   Click image for larger version
ID:	97657   Click image for larger version
Old 02-05-2004, 01:40 PM
airmcn_2
That Looks Cool Man!!!! Thanks
Old 02-06-2004, 06:43 AM
Jules
That looks like a nice F-15 do you have any planes to kit it, and if so how much are you thinking of.
Old 02-17-2004, 02:51 PM
mjblack
anyone fancy seeing a Depron F-15 realy fly?
visit www.rcelectricflight.com and check out eh new vids.
cheer all,
Mike.
Old 02-23-2004, 12:27 PM
finchero
My Feedback: (-1)
here's a new pic of the f15, little more paint and detail and it should be complete
Old 02-24-2004, 11:14 PM
finchero
My Feedback: (-1)
finished and I'm very proud. I didn't know it would turn out as well as it did. hope it doesn't crash on it's maiden flight. everyone should try to build without plans, it gives you a sence of freedom.
ID:	104760   Click image for larger version
Old 03-02-2004, 09:17 PM
Speedo125
This foam board looks perfect for a Mig 29 EDF I'm planning. What are you using for adhesive?
Thom
Old 03-02-2004, 09:50 PM
finchero
My Feedback: (-1)
5 min epoxy and light spackle to fill the cracks. nose is all eps foam, paint is acrylic with a final clear coat.
Old 03-10-2004, 09:31 AM
Speedo125
OK, epoxy sounds about right. I made a raid on Wal-mart last night and I'll start cutting foam board Sat. morning. I'm using a 90mm WeMOTec fan on 20 cells. I'll hide the fan between the two original tailcones. Stretch the bungie, stomp on da pedal and let 'er rip!
Thom
Old 03-10-2004, 08:35 PM
ralphyfly
if you soak the foam board over night in water, say the bath tub, you can easily remove the paper if your wishing for a easier sanding surface.
Old 03-16-2004, 05:42 PM
finchero
My Feedback: (-1)
guys here she is now with panels and here little brother
Old 09-02-2005, 11:41 PM
runwaydodger
runwaydodger's Avatar
darn it my secret is out. been using this stuff for about 3 years. good stuff, i store mine in the bathroom and the presents of shower condensation makes the paper peel off in one sheet most of the time. your jets look good. also great for making 3d planes, an a lot easier than ordering the stuff off the net.
who says wal-mart is good for nothing.
gorilla glue, handymans adhesive, and 3m spray glue works good too.
Old 10-22-2005, 07:02 AM
c-grain
Here's a couple of deltas I designed using Elmers foamboard with .188 carbon tubes for the L.E.s and T.E.The only draw-backs of this stuff is the paper on the board tends to cause warping if you don't seal it with paint while it's still flat and it's about twice as heavy as Depron with both paper sides still attached.However, it's very strong and cheap!I too have been using the stuff for over 4Yrs.Anyway,the little one has 330 sq.in. and the big one has 1000.They are called the X330&X1000 respectfully.
Old 10-26-2005, 04:48 PM
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Default RE: *finished* f 15 foam core board
What section of Walmart do you find this foam board?
Old 10-28-2005, 12:23 PM
sobamanismo
I ran across this suggestion as well, I've cut out the pieces for something closer to a trainer (sorry to highjack your thread). What's the consensus of take the paper off to save weight, vs leave it on to maintain rigidity? I pulled the paper off a test piece and it was LOTS more flexible than the paper'd cutouts.
