Propeller Pitch Speed vs Level Flight Speed
My Feedback: (9)
Sorry Mark. Way too many variables. As an example a thick wing profile or 3D only plane turning a 13x8 at 11,000 RPM will have more slippage than a pattern type plane with retracts and a thin airfoil turning the same prop at the same RPM. There is probably a formula if you knew the CD of a particular airframe. It's way over my head if so. You might ask some of the guys in the aerodynamics forum if you don't get an answer here.
David
David
It is like climate and weather.
Climate is what you expect.
Weather is what you get.
Your actual airspeed will not exceed your pitch speed in level flight and will normally be less, as per my statement above.
