Garolite G-10 substitute??
CA
RE: Garolite G-10 substitute??
I too have used plastic. Cutting boards look promising. My stash is unknown plastic of various thicknesses. None has melted or given me any trouble. Perhaps a plastics shop would sell or give you some scraps? I have also used aluminum with only thick gaskets to act as insulators. That worked too and did not cause the gas in the carb to boil. Mostly I have been using 1/4" phenolic board lately. It has enough thickness and strength to give the carb screws a good bite. I have not noticed any problems in how it runs with the short intake plenum. Maybe try 1/4 or 3/8" aluminum with thick gaskets?
I thought of using aluminum, and I have some plastic carb spacers I could use with it for insulation, but I was worried that the carb mounting screws themselves would transfer enough heat to be a problem. That's why all the stock manifold insulators use two bolts to mount the insulator, and two different bolts that attach only to the insulator to attach the carb. It doesn't allow a heat path from the engne to the carb through the mounting screws.
AV8TOR
AV8TOR
My Feedback: (51)
Aluminum isulator blocks are used on r/c boat engines with teflon gaskets,between the block and engine and one between the block and carb.Should work on any engine.I don't know if the ones for the Zenoah engines would work,but they all use Walbro carbs. Maybe find a sourse for Teflon gasket material. http://www.cc-racingengines.com/inde...mart&Itemid=53
Yep, still live in Penasco, though I've been spending a lot of time in Tucson this summer. Just herniated another disk in my back, gotta go back to Tucson to deal with that tomorrow in fact. Hope things are going well with you.
AV8TOR
AV8TOR
