Walbro Remote Carb.
Old 07-16-2011 | 08:44 PM
Default Walbro Remote Carb.
Dear all,
After a long time testing my G90 on gas, with a walbro on it, I can say it was a success...
Well, I have had some revolutionary(or not) Ideas.
1) I would like to have a Walbro carb on a OS.46 engine, but I cant fit the carb in there due the engine dimensions, right?
2) looking at a 4 stroke engine, the carb is not fixed straight to the engine body, there is a pipe for it, right?
3) What if I male a pipe and put a walbro carb somewhere like on the side of the engine?
Mauricio
Old 07-16-2011 | 10:04 PM
Default RE: Walbro Remote Carb.
yes you can do that. just make sure the inside dimeter is not smaller than the venturi and the pipe is not too long.
btw.
what carb will you fit on it?
Old 07-16-2011 | 11:53 PM
av8tor1977's Avatar
Since the Walbro carb has a fuel pump, you could use a bit larger venturi than the original .46 carb, and gain some power.
Are you going to run the engine on gasoline or glow fuel?
AV8TOR
Old 07-17-2011 | 12:57 AM
w8ye's Avatar
My Feedback: (16)
When you get it done, upload some pictures for us to see or it didn't happen
Old 07-17-2011 | 01:43 AM
Subscribed.
Old 07-17-2011 | 09:38 AM
av8tor1977's Avatar
Note that while the Zama carbs are a touch smaller physically, in my experience they won't tolerate methanol at all. The diaphrams go bad in a matter of hours.
The Walbro carbs are designed for bigger engines, so if you decided to run glow fuel, one MIGHT flow enough fuel. If not, you can "cheat" them into flowing a bit more by raising the metering lever a touch. If that doesn't work, you'll have to start enlarging internal passages. The WT-499 Walbro is designed for glow fuel, but it would flow way too much for a .46 and would be extremely sensitive to needle settings. (Besides the venturi size is much too big for a .46.)
The stock Ryobi engines run a very small venturi carb that might work....
AV8TOR
Old 07-17-2011 | 05:10 PM
I thank you all for the replies!
Converting a .46 os any small bore engine is just a project for while...
Let me talk about my Self, I'm 35 and I'm a Project Manager for special project. What I mean is, when a company has a project and nobody have done that before, I join people from different skills to make that happen.
making experiences is part of my relaxing time.
Converting engines is not difficult, my challenge is to make it work the way I need...
I loved the experience of using a Walbro carb, since I have no fuel tank pressuring issues anymore! Therefore, I would like to try walbro on small engines and see what happens!
My first idea is to place the Walbro by the side or in the back of the engine... and to be honest, I still need to buy a trainner in order to make flight tests, bench tests is good, but I prefer the flight test...
I was just concerned if the walbro would manage pushing fuel into the engine...
By the way, does anyone here has a pipe bending machine?
Also, I would love sugestions about wich walbro I should use. I wanna use the those with pump on it.
Question,
Lets imagine a Walbro is way too big for my needs, what if I use a very thin fuel tubing from the tank? what if I smash a piece of brass tubbing and put it inside the fuel line?
Thank you all for your help and sorry for my english, but that is ot my mother tong...
Mauricio
Old 07-19-2011 | 02:22 PM
nobody?
Old 07-19-2011 | 04:05 PM
Maximiliano Galvez's Avatar
me !!!
Old 07-19-2011 | 07:58 PM
My Feedback: (13)
ORIGINAL: mvarzoni
Question,
Mauricio
With a fuel pump neither of those methods will get what you would want, if it's just slightly more fuel flow than needed you should be able to bend the regulator lever down a little. I have a few walbro's with 6-7mm venturi's but most of them only have one needle
Old 07-20-2011 | 08:57 AM
walbro carbs venturi in mm
&lt;meta http-equiv="Content-Type" content="text/html;charset=UTF-8"/>&lt;title&gt;motorpower-metingen</title&gt;<table bgcolor="#ffffff" border="1" cellspacing="0"><caption>carbs</caption><thead><tr><th bordercolor="#000000" bgcolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">carb</font></th><th bordercolor="#000000" bgcolor="#c0c0c0">venturi</th><th bordercolor="#000000" bgcolor="#c0c0c0"><br type="_moz"/></th><th bordercolor="#000000" bgcolor="#c0c0c0"><br type="_moz"/></th><th bordercolor="#000000" bgcolor="#c0c0c0"><br type="_moz"/></th><th bordercolor="#000000" bgcolor="#c0c0c0"><br type="_moz"/></th><th bordercolor="#000000" bgcolor="#c0c0c0"><br type="_moz"/></th><th bordercolor="#000000" bgcolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">remark</font></th><th bordercolor="#000000" bgcolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">date</font></th></tr></thead><tr valign="top"><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">WA102-1</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">6</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td><td bordercolor="#c0c0c0"><br type="_moz"/></td><td bordercolor="#c0c0c0"><br type="_moz"/></td><td bordercolor="#c0c0c0"><br type="_moz"/></td><td bordercolor="#c0c0c0" align="right"><br type="_moz"/></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">no bulb pump- rowena motors</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td></tr><tr valign="top"><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">WA101</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">6.5</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">0</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td></tr><tr valign="top"><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">WT521</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">7.14</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">0</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">0</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">Mitsubishi equipment</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td></tr><tr valign="top"><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">WT206</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">7.14</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">0</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td></tr><tr valign="top"><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">WT539-1</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">7.94</font></td><td bordercolor="#c0c0c0" align="right"><font style="font-size: 10pt;" color="#000000" face="Arial">0</font></td><td bordercolor="#c0c0c0"><font style="font-size: 10pt;" color="#000000" face="Arial">
</font></td></tr><tfoot></tfoot></table>
Old 07-20-2011 | 09:09 AM
gkamysz's Avatar
My Feedback: (19)
Wow, the html didn't mix well with the site. I began making a list of carbs with the data on the Walbro site, but soon realized it would take ages.
Old 07-20-2011 | 11:25 AM
<span style="font-family: Courier New;">like this perhaps? Turn on HTML in your preferences. It's worth the trouble.
Carb type, dia remarks
</span>&lt;meta http-equiv="Content-Type" content="text/html; charset=utf-8">&lt;meta name="ProgId" content="Word.Document">&lt;meta name="Generator" content="Microsoft Word 11">&lt;meta name="Originator" content="Microsoft Word 11">&lt;link rel="File-List" href="file:///C:\Users\pe\AppData\Local\Temp\msohtml1\01\clip_fi lelist.xml" /><span style="font-family: Courier New;"><![if gte mso 9]><xml><w:worddocument><w:view></w:view><w:browserlevel></w:browserlevel></w:worddocument></xml><![endif]><![if gte mso 9]><xml><w:latentstyles latentstylecount="156" deflockedstate="false"></w:latentstyles></xml><![endif]></span><style type="text/css"></style><span style="font-family: Courier New;"><![if gte mso 10]><style type="text/css"> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0cm 5.4pt 0cm 5.4pt;mso-para-margin:0cm;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style><![endif]> </span><p class="MsoNormal"><span style="font-family: Courier New;"><span style="font-size: 10pt; color: black;">WA102-1 6.0 bulb pump- rowena motors
WA101 6.50
WT521 7.140 Mitsubishi equipment
WT206 7.140
WT539-1 7.94</span></span></p>
</meta&gt;</meta&gt;</meta&gt;</meta&gt;
