turbocharged 25cc homelite whipper snipper
#76
RE: turbocharged 25cc homelite whipper snipper
CRUSTY
I'm not well known for being a diplomat either, but I'm trying! - ridiculous thread, yes, - but it's fun!!
#77
Afghanistan? - last week it was Vietnam, - either he travels a lot or he's ashamed to tell us where he comes from, but he does usually hit the nail right on the head - brutally!
#80
ORIGINAL: Willdo
Guess it would stop the venturi effect working,
The more volume of air going through the carbie from the turbo on HIGH revs would only increase more fuel flow. Ether flooding the motor or creating more combustion.
With idle the turbo spins very little, there 4 very little pressure if at all on the fuel line.
So I don’t get where Ur coming from.[sm=sleeping.gif]
[:@]NOW HEAR THIS!!!!!!!!!!!!!!![:@]
P.s. ppl read the (RCU Policies) before opening Ur mouths.
I won’t reply 2 ppl that cant say anything other than complete negativity.
when did this all have 2 turn in2 a debate. the motor works Excellent.
what do I have 2 prove [sm=redface.gif]
stop Or I will be forced 2 leave this forum. OK
I am only trying 2 give ppl ideas on making new things.
Don’t get me wrong constructive criticism is good
Willdo Would U like me 2 drive my Subaaaaaaaaaaaru over there?
With a blow up DOLLY 4 U. Then I will finely C U happy.
#82
Hey Willdo looks like rugby isn't popular in the states. I recieved my planes for the Wren turbo-prop today, looks like it will be a cool project, 7+ hp from a 1,8kg engine. Fuel comsumption is about 190ml/min. What a beast
Tim, chill dude the more wound up you get, the more of a target you will become.
#83
Sounds good to me Rupurt, I'm very interested. I've sent a PM. - don't want to encroach on Tim's thread.
#84
Thanks heaps Tim much appreciated. No rush because I know how much it'd suck to have to do. Ciao. Thanks again.
#85
tim, I suggest you do some reading on the work of bernoulli, it will help you understand venturis
I can see you are on the defensive, but open up to advice given and make truthfull comments on your endevours and I am sure you will get a much better response
#86
TX
does any one have any links to a pro made turbo setup for these little engines, i would like to study up on them a little more
all of this has peaked my interests, and im thinking of making a turbo myself, i understand the basics, but im a little rusty on all of the specifics.
#87
5k, there are'nt any, because they dont work.
I saw a unit intended for model cars being sold a year or two back, but of course it didnt work, the rc car guys tried to convince themselves it made power but it was all in the mind
#89
Well, this thread is a little silly in all the goings on and I hesitate to get into it but...
Two stroke supercharging could work. It might not turn out to be feasible, but it definitely could work. Back when Hitler commanded Ferdinand Porsche to build the "Peoples car", (the Volkswagen), he was working on a four cylinder two stroke engine that had two cylinders supercharging the other two. He never got to finish developing it because Hitler was pressuring him to get the car on the road. You won't see much more two stroke development from the big concerns now because of fuel efficiency and smog problems today. I believe there are two stroke turbocharged diesel engines made, but I don't feel like researching it right now.
Anyway, just my dos centavos...
AV8TOR
AV8TOR
#90
Yes detroit Diesel with valves, designed specifically to use forced induction............nothing like our purely piston ported rc engines
edit......I am not saying I believe you cant make a turbocharged two-stroke, I am sure there are many marine examples, but I am saying adding one to an otherwise normal piston ported 2-stroke like the ones being discussed here is not going to give worthwhile gains, even if properly engineered
edit two... Sorry Now I am getting ridiculous, I'm just re - stating my position over and over which is adding nothing to this discussion so I'll not bother this thread again.
Good luck Tim
Good luck Tim
#91
Crusty is that an opinion or is that experience. If a change in altitude can change performance I believe a turbo could have the same effect. I am confident you are wrong.
#92
IL
"Crusty is that an opinion or is that experience. If a change in altitude can change performance I believe a turbo could have the same effect. I am confident you are wrong. "
Well how high do you plan on flying your model?
#93
IL
"stop Or I will be forced 2 leave this forum. "
May the forced be with you
So anyway, Have you blowed one up yet? Youll never know how better it is until you go beyond its intended duty cycle. How about some nitrious. It would be a compliment to your turbo. Keep up the good work.
#94
ORIGINAL: Rupurt
edit...oh and please try and understand (it seems to be escaping some people here) the thread is about turbo-charging a conventional piston ported two stroke
and as for the snide little dig, no its not from experiance its from lots of reading and understanding...I also know that the moon has a dark-side...also not from experiance
#95
It wasn't a snide dig sorry if it came across that way, I am just curious as to why you say it wont work. I have also not had experience turbo charging a piston ported two stroke but have done a lot of reading and understanding, and from what I understand it can be made to work.
"what you got to back yours up" what huge body of evidence?
There is a huge amount of evidence that shows a two stroke engine runs better at higher pressure. It doesn't help anyone just saying it won't work, tell us why.
#96
Dave I was referring to people who flight at higher altitude. With the lower pressure they get lower performance. There a couple of guys on this forum who fly at altitude and they will tell you everything is less efficient higher up.
#99
Rupurt, I know you are intelligent and have a lot of knowledge, , im sure you know, the main drawback is port overlap, you just blow all the charge out the exhaust. this has already been discussed .
your analogy to pressure change with altitude is not the same as pressurising the intake only, when altitude changes pressure it also correspondingly changes pressure at the exhaust end, so no difference as far as the engine works, just a change in charge density.When you pressurise just the intake but not the exhaust the engine then behaves differently
#100
I thought that would be the reason, but remember the turbine will increase the exhaust pressure, it is possible some extra restriction in the exhaust may be necessary to stop the charge disappearing out the exhaust. I think the main issue here is of practicality(Why bother?), I would like to see tim get it going just for the hell of it.
"this forum has turned into an arguement" it is a matter of opinion, I see it as a heated disscution
