craftsman 55
My Feedback: (21)
NY
craftsman 55
I have a crafsman 55cc and (I got used) at some point in its life some one welded the nut to the crank. When I ground down the weld and tried to crank the nut off it snaped at the base of the threads. If I were to take the jug and spin it 180 to drive the prop off the clutch side of the motor but still get the proper rotation will it run right. It's going to be EI so no mag needed and a friend ownes a machine shop so drive hub is no problem just need to know if spinning it 180 will work. Thanks all in advance.
RE: craftsman 55
Do you even have to turn the jug around? Unless you want to have the carb and exhaust on the same side they were on? Will a piston ported or reed valve engine run either way as long as the ignition pick up sensor is set properly for that desired direction you want? How about glow conversion of a piston ported or reed valve gas engine, will it run either way like the old Cox reed valve engines?
Richard
Richard
RE: craftsman 55
My Feedback: (16)
RE: craftsman 55
Some piston ported engines have channels in the block that are different on one side than the other.
often the intake ports are set up schnurle style to force the intake charge away from the exhaust and the cylinder passages will not match the crankcase when turned around.
NC
RE: craftsman 55
ORIGINAL: supersparky
So it will run fine backwards? I know glow will run backwards but not well.
