RE: craftsman 55
Do you even have to turn the jug around? Unless you want to have the carb and exhaust on the same side they were on? Will a piston ported or reed valve engine run either way as long as the ignition pick up sensor is set properly for that desired direction you want? How about glow conversion of a piston ported or reed valve gas engine, will it run either way like the old Cox reed valve engines?
Richard
