Honeybee King v2 tuner shop
#4851
RE: Honeybee King v2 tuner shop
ORIGINAL: hamid_fireage
One other thing, I have a 10T pinion and dont know if its good for the 3800 motor or not? Im trying to post a picture of it.
Thanks again.
Thanks again.
#4852
PA
Hi Rusty,
Are you saying that the 43t belt will not work with the cnc tail assembly. I currently use the 43t setup but will go back to the stock if necessary.
Jim
Jim
#4853
ORIGINAL: reel109
Hi Rusty,
Jim
Hi Rusty,
Jim
#4854
OK
Hey Jim, what I am saying is I have not tested with that gear set-up so I do not know how it will work. Like 53, I think it may help and adjustments can always be made to accommodate but I personally have not tested or flown that set-up so I do not know if it will be too much or how it will react. If I get a chance, I will throw the 43t on one of my kings with the tail mod and do a little testing to see and post my opinions. You know, in a situation like this unless it is first hand knowledge it all just guessing so some testing will need to be done in order to give any definitive answers but I will get them out on the thread as fast as I can.
Hamid - I think you will be okay with the 10t, and the length of the shaft will depend on how tall of a spacer you make, but I will send specs to your email address in a short and you can see if you can make one up, if not I assure you that is no trouble on my part to shoot one out to you for no charge as long as you pay the shipping, it is not about the money dude, its about flying, lol.
#4855
Thanks Rusty - I will check your specs and try to make one. You and other people on this thread helped me a lot. If I cant install a little motor on little a plastic mount then it would be better try not to fly any helis.
I will send you the results.
Cheers.
Cheers.
#4856
MI
You should get rid of that press on pinion and get one with aset screw. My first pinion on the HBK2 was a press on and its shorter so you have to get it perfect (plus once you put it on, you cant really adjust it like you can with a set screw pinion.) Just my 2 cents.
#4857
MI
ORIGINAL: Rosebud6
#4858
OK
Here is a pic of the one I did using an hdx tail boom, and one I did using an Eastman shaft. I will post a pic in a minute if I can find it of the falcon boom on a king with the upgrade I just did recently on a boom extension.
#4859
thanks crash and rosebud6 - My first effort is to make the motor mount. Then going to buy a removable pinion.
I know a little electronics and have three sets of 25W, 40W and 60W solder iron, and have a solder sucker too. But i dont know if the 63sn/37pb solder would stick on brass.
Another thing is; if I lift up the motor by a 2mm spacer then the motor wont hit the front servo horn?
#4860
CA
I notice the hdx300 uses a 40t main pulley so a 43 tooth is going to be a better ratio only by 3 teeth but thats still in the ball park.
#4862
CA
I thought the hdx boom was 9mm. I have what I thought was one here and it measures about 9mm but its only about 275mm long or so and thats too short isnt it. Eastman shaft thats the arrow shaft? From Walmart? Neat as I am going into a Walmart today I will look in sporting goods maybe I can buy just one
#4863
CA
I can make my 8.08 fiberglass boom into 9mm OD by putting some hard sleeve fiber reinforced pvc heatshrink on it, that will take it up to 9mm as I was testing some on one end of a boom where it went into the frame (made it too big).
#4864
MI
ORIGINAL: funflier
Crash thats a heck of a long discription of sweat soldering it on
LOL...when you're actually doing it...it gets a little intense. If you get a cold solder joint, you know it quickly after you spool up. I've had the solderjoint give out, motor goes like crazy, pinion barley turns....heli lands quickly too.
#4865
CA
a welder that made a cold solder joint... noo way
oh wait I did that once on a copper pipe that I didn't clean, lucky I hadn't closed up the wall, one little tiny pee of water so fine you could hardly see it. Would have playes havic with the drywall in about a week.
#4866
MI
ORIGINAL: funflier
#4867
MI
Sorry for useless babble, just going by my experience with press on vs set screw. Press on was smaller and twisted after a crash, the set screw one has gone through 4 or 5 crashes with out a scratch.
#4868
Thanks Rusty - I read your sepecs that was realy helpful. I found some cnc machinists in my area and they make this plate with cheap price.
My suggestion was Aluminium but they say TEFLON is better for this duty with cheaper price and easier to work on. I thought teflon is the material used in cooking dishes!!!! Any idea?
And is it ok to make it with 2.2mm thick plate instead of 3. Because if I want to make it with alumn, they have not more than 2.2mm thick plate.
Thanks again
Thanks again
#4869
OK
Teflon would be fine, like I said I have used tupperware as a good spacer, I think the you will be okay at 2,2 also, the lower profile you can get it with the proper clearances the better you are.
#4870
so i messed around with pitch curve today and set it to -2, +5, +9 and now the thing lifts off right around midstick just like my Evo50! sooo much better and more familiar to fly. i dunno why i used the same curve as the stock radio before. duuuuhh.
i also moved things a bit to pack everything better, so the stock canopy fits with more ease. i still wanna get a bigger one. anything from Trex or Blade that's lil bigger than stock and compatible? those are the only ones LHS sells.
i also ordered myself a walkera 4#3B for those rainy days. it's a bit shorter than a HBK stock blade and has 4ch. all i need is a sub-micro Airwolf body lol
#4873
MI
I like that last one Beta. Is nice. I have not had a chance to test out those settings on the Danlion for the DX7 you sent me. Will let you know how it goes.
Quick question on CNC heads. Should I add some type of Lube to the swash ball and main shaft? As i recall, the plastic swash had some type of lubricant in it, but its been so long since I've had a new plastic swash for my HBK2 i cant remember if it did. Just wondering cuz the EXI MA450 I just put together is bone dry in that area. Metal to metal seems like it would wear out real fast without anything in there.
#4874
i really like that blue one, red would prolly be easier to see. what is it (the canopy, not the heli)? is that what you sell?
not a fan of bare carbon fiber though. my 1:1 Evo's wing's airfoil comes as such, but that's about as much of bare CF as i can stand lol.
Rosebud, a lil oil is always good for many things. heh heh heh. i would use a couple of drops of "3-in-1 oil" found at Home Depot. it's in a white plastic bottle or metal can usually. it's thicker than WD40 spray version, so it stays on longer. put it on the swash bearing, ball, and shaft. i would also put it on the rear tail shaft where the slider goes. just use small amounts and wipe excess.
#4875
CA
the metal swash plate is packed with grease on the inside for life so don't put anyting on the ball or it will wash the grease out and it may start sticking. Oil the main shaft, never oil plastic or nylon parts or any ball links as it not only makes the balls slide easier but also come off easier and we don't want that.
