Honeybee King v2 tuner shop
#2351
WA
RE: Honeybee King v2 tuner shop
ORIGINAL: shizack
I gotcha. Had as similar issue, but fixed it early on. Take the links off the slider and make sure not to lose those little screws. Ream out the screw holes just a tiny bit - I used the smallest Dremel drill bit - and reattach the links. You can still get them as tight as you need them to be, but now the links can "pivot" in the larger holes. This should minimize or eliminate the binding that occurs when the blade grip ball moves through the top of its arc of travel.
Haven't had a single tail issue on the King since I did this, even with the stock gyro and servo.
I was "inspired" by the pivoting mechanism of the Trex slider.
#2352
IN
makaluch, The Menu's may be different but the setup should be the same, Used just about the same setup on my friends trex 450 on a dx7. I fine tuned it some like making the normal mode pitch setting linear starting at -1 pitch to make it less jumpy. I was going to get the dx6i but wife got me a dx7 for xmas and im still bragging on her for it . I never really believed all the hype about how much a good radio will help until I got one it really is night and day the way it flys now. And now I can only blame myself when I lose to gravity. Only glitches I get are in my thumbs.
#2353
YeeeHawww,I just got some blades (3 sets) in today.Now when my balancing doodadd gets here,I can have some more fun.I love it when I have a stock of pieces/parts.
-lohchief
-lohchief
#2356
MI
ORIGINAL: lohchief
I just love tech speak ;}>
-trash
ORIGINAL: makaluch
hehehe...doodadd. I need one of those doodadds too!
-trash
I weigh my blades on a re-loading powder scale...very accurate. Just add tape to the light blade....fixes it right up....doodadds...LOL.
#2361
MD
ORIGINAL: Druss
bah, you guys sound like a bunch of women at the mechanics shop trying to explain why her car won't start.
#2363
WA
I had a site that showed how to balance the blades.First to fid center of each blade and match, then balancing the blades to each other. here it is
http://www.trextuning.com/bladebalancing.php
O' and I forgot you need a watchamacallit and a thingamajigger for it to really work.
#2364
WA
Anyone have instructions on how to program the Esky 25A ESC with the Esky 3900kv outrunner? Just upgraded and want to make sure I understood those sketchy directions.
-Yeah...I need a bigger house so I can put more of my stuff in it. My stuff gets used and my junk goes on FleaBay...her junk just sits there and makes friends.
#2365
Hi there guys! Lots of good info. i'm all new in this bussines, i got my bird HBK2 of eBay. Never had a chanse to fly it yet.
No meter what i tried i can't get the motor to work. When i turn my transmitter on , set the troutle & trimer to lowest seting then conect the batt. on the heli
the gyro red light bliks and then turns on stady but wont turn green. Any one please help []
#2366
WA
the light dosent turn green it just stays a steady red when its ready.if your motor is not spooling up first make sure the throttle kill switch is not on its the one on the top right of the radio should be pushed towards the rear. other than that check all connections .
i know i left my thingymajig somewhere i'll have to find my kaboodle to search for the lost thingy fixer
#2367
Hey guys got a question for ya. Just got my HBK2 in yesterday and charged the battery for the first time last night. The charge took almost 3 hours for the first charge. Is this unusal for the 1st charge and what kind of charge time should i expect for further charges. Other than charges the bird flys great. Very impresseive machine for the price.
Jeremy
Jeremy
#2368
MI
ORIGINAL: jeremyswade
Jeremy
Jeremy
#2369
Hey thanks Crashcrash. I thought 3 hours was a little much my self. Working on the second charge right now. So we'll see how it goes. Also another question. When I plugged the batterie this morning and flew for a few min then sat the bird down to do some trim work. When I plugged It back up and let the gyro sync I had no thotte at all. The CCPM worked but no motor. I hand spun the blades while giving it throttle and it started working fine. Anthing I'm doing wrong here or something defective in the heli?
#2371
MI
ORIGINAL: crimsonrain22
jeremyswade, If you still using the stock motor that is the first signs of its death, Time to go brushless.
Agreed...DO NOT get another stock motor...go brushless. JAG Hobbies has a 3100kv/25a ESC combo for $40....best money you could spend. Order the 10T pinion for the motor 2.3mm shaft. Can easily be pressed on in a vise.
#2372
Yeah just got it yesterday so i'm still really learning. I plan on going brushless very soon but fiquered i'd get the most out of the stock motor as possible. Also fiquered out the motor problem but thanks anyway's guys.
#2373
MI
#2374
NC
I have not set up a JR radio yet, But I am having a heck of a time setting the EK2-0704A HH gyro up on a DX7. I have worked with the Futaba 12Z, 9C, Optec 6, and DX6. I have built 5 HBK2's for people at the LHS. The one I am working on now fly’s well except the tail just won’t hold in HH mode. It just seems lazy. When I flipped back into normal, it wanted to Pirouette. I am using a Hitec 65 on the tail. If anyone has any suggestions or links on how to set up the Gyro on a DX7, it would be greatly appreciated.
PS. I would not recommend using the E-Flight 400 Speed inrunner motor. I snapped a shaft in flight doing forward rolling flips on my HBK2. When it came out, it seemed to have no power to pull up as it headed for the ground. I was able to get it level before it hit the ground at a 20 deg angle, but still lost a CF Blade, Feathering shaft, canopy, and landing gear. The main gear is still in mint condition. Usually the main gear gets roached if the motor is still running and in contact with the main gear. The main shaft still looks good, but I cannot tell until I get a new motor and fire it up. I expect it will be bad also.
ORIGINAL: krossk
Does anybody have any experience setting up a King 2 with a JR XP8103 radio? The closest info I can find is for the DX-6/7. It seems like this is close enough to at least be in the parking lot of the ball park, but if anyone has actual settings from the 8103, I'd be most appreciative for the info.
Thanks all and "Heli New Year!"
#2375
