ESKY LAMA 4 THREAD
#3251
AL
RE: ESKY LAMA 4 THREAD
ORIGINAL: CFDfireman
Tony, I can hardly wait for a vid of you flying your HK-450. You must be getting a good feel for it by now. Just stay away from those pile of bricks in your back yard
#3252
Hi Peter, Thank you for the update. 15 flights is pretty impressive. I just checked my log book and I get about 17 flights with my 1.2v 2200mah rechargables. Not sure if it's worth the change over to a lipo. Another thing is, there's not enough room in the compartment for a lipo alarm( this is my mcX tx). I could ''guess-ta-mate'' but, I would risk ruining a lipo.
The reason leethetreeguy wired the lipos in series is because he used lipos that were on hand. As I understand, he leaves the cover off on the TX compartment and keeps them in place with velcrow.
Does your Walkera TX take 8 AA batts?
I've just charged the Tx lipo again after 21 flights this time[sm=72_72.gif] - that is a large discrepancy - I wonder why?[sm=confused.gif]
The Walkera Tx that I used to have (and prompted me to purchase a [link=http://www.rchelicoptershop.com/catalog/hyperlithium-111v-2200mah-lipo-battery-for-walkera-transmitter-p-927.html?osCsid=qjvq6pme2jtg5edrdao2eknmc7]11.1V 2200mAh Transmitter Lipo[/link]) contained a black plastic holder with 4xAAs on one side and 4xAAs on the other (8AA=12V in total) terminating in a male JST - and a JST female already in the side of the battery box to plug it into.........
The WK2402 Tx that came with the [link=http://www.besthobbysite.com/shop/product_info.php?cPath=150_152&products_id=12592]2.4G Walkera CB180D[/link] has a similar system. This is easier to adapt to run a Tx lipo than a common Esky Tx .................[sm=wink_smile.gif]
Peter[sm=shades_smile.gif]
#3253
MA
Peter, the descrepancy between 15 flights and 21 maybe due to the newness of the batt. Maybe after a few cycles it will improve more. That would be nice
Mike.
Mike.
#3254
AL
I don't understand why they are would need 12v to power a 2.4ghz transmitter module. My DX7 runs fine with a 9.6v nimh pack with a range that's unbelievable.
It's almost like they design the transmitters with the intent of making it difficult to find a battery pack to fit it. I honestly wouldn't put a lipo in my transmitter, simply because I've left mine on and forgot about it one too many times.
#3255
ORIGINAL: barak1001
It is better to do this with a Lipo than ruin a perfectly good set of alkalines - believe me - the [link=http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270540766730&ssPageName=STRK:MEWAX:IT#ht_2133wt_732]BEEPER[/link] tells me if I have done this anyway.... The power trends of lipo are ideal for Tx as they don't lose power in the device if you switch it off between flights on different days - another bonus!
All my other 2.4G Tx are 4xAAs - just this Walkera one (WK2402) - it is a mystery to me also[sm=confused.gif]
#3256
Have not been to well thus flying had to take a backseat. As I have to re-do the 4 in 1 adjustment and my new silver canopy does not have holes in it for a screwdriver as the orange fuselage had, can I fly it without the canopy? It will obviously save a lot of time not having to remove and put back a few times and I do not want to make holes in the new canopy.
Will also be taking my BOL out fot it's first flight this coming weekend.
Edmund2
#3257
ORIGINAL: Edmund2
Edmund2
Edmund2
I hope you are feeling a little better each day![sm=49_49.gif]
The good news is you CAN fly without the canopy (with the fuselage still attached) - you can trim the elevator a couple of clicks forward to compensate for the weight of the absent canopy - but it is best to drill a hole in the side of the canopy window. You can use a drill just spun between your fingers or a heated poker or soldering tip to melt a hole
Take care.
P.S. Best of luck with the BOLs maiden flight - post on [link=http://www.rcuniverse.com/forum/m_8216608/mpage_138/key_/tm.htm]the Big Lama thread[/link] how it behaves......
#3258
PA
ORIGINAL: Edmund2
Edmund2
Edmund2
usually whenever Ido fly (unfortunately not too often lately ) I fly my bird without the canopy (but I also have to admit that I dont fly outdoors, but strictly inside ... ) - here is a little movie about me flying mr.0815 in my most favorite flying area (an old, formerly unused airline club that I just lost access to) ... which also happens to be the first movie I ever made about me flying helis ... as far as the use of canopies, nothing changed since ...
regards (to all)
Sven
http://www.rcline.tv/video/1285/mein...rsterhelimovie ... enjoy! - And to whoever does: Thanks for watching!!
#3259
Sven your heli really moves mate, im impressed. It is brushless though right?
Stal.
ps. Im waiting till i can get a canopy for my bird before i fly it again. Im not going to fly it outdoors without one.
Stal.
#3260
Sven, having tried in vain yesterday to watch it on my cell I managed to get around the firewall this morning at work. Like Tony indicated very impressive fligh, however was that a crash right at the end?. Used a Dremmel bit and now have two nicely aligned holes for the screwdriver in the canopy. Can not wait for the kits to arrive to change mine's appearance. Have the whole of Saturday set aside for flying my two Lamas. CP will still remain under the bed - suppose to at least much later in the year.
Just wonder how Peter's l4 Spaceship modification is progressing?
Edmund
Edmund
#3261
PA
ORIGINAL: stalyoni
Stal.
Stal.
the heli in this video flies on Xtreme 180s with carbon brushes and a 7.4V battery - ele was in the 3rd, ail in the 2nd hole ...
As long as you keep on flying like me only inside, xtreme motors are sufficient. (btw. I still get almost 10min of flying out of them anyway ....)
Sven
#3262
It flies well sven, nice job mate.
Stal.
ps. been getting alot of stick time on realflight g4.5 on the CP pro so i can get ready for my new blade SR soon
Stal.
#3263
ORIGINAL: Edmund2
...and that is where the CP should remain
P.S. The spaceship is progressing slowly - only just moving actually - I'm still gathering parts, but I'm off bush camping over the weekend with the fam.....
#3264
guys i was really bored today so i was looking on the web and found this simulator software. Hangar 9 FS ONE.
[youtube]http://www.youtube.com/watch?v=GnNb7GdbERM[/youtube]
After watching this video i thought i would give it a go. After hours of mucking around i got it working and it was a big dissapointment.
You only get a few models, blade cp pro, blade cx2 and a few other cp helis. I did like the look of it but as a sim it sucked.
I still think realflight is the best and then clearview.
BTW pete ive been in contact with Stefan at clearview and he said you can run two copies, one on your laptop and one at home. PM for the details.
Happy flying all
im off the pub
Stal.
Happy flying all
im off the pub
Stal.
#3265
AL
I was told that if I wanted to practice on planes as well as helicopters I should get a copy of RFG5, but that Phoenix RC was a much more accurate simulation of helicopters. I should have my copy of Phoenix in a few days and I should be able to report back on realism of helicopters in both then.
#3266
Hey again guys,
I'm back & I'm sore - I found a couple of muscle-groups that I didn't think existed![sm=confused_smile.gif] Brendon, I would love to ask you for details on how do run Clearview on my notebook and PC - but I just sold my notebook to one of the guys at the campout. When I replace it I will be sure to ask you then........ Thanks for the info that it is possible.
Tony,
How much $ does Pheonix cost?
Thanks - (I'm going to a bath & bed soon)
Peter (*ouch*)[sm=shades_smile.gif]
Tony,
#3267
Loaded Clearview Demo on my PC this weekend. Could not find a way to get my TX as the control, only indicated they keyboard. So I gave up and played on FMS. After changing the settings to be as on my TX it was a piece of pie to fly everything.
As indicated last week I had to re-do the 4in1 adjustment. No problem getting the tail staedy but for the lov eof me I just can not get thegain rigth for it to stay on the same heigt when Iuse the rudder. AfterI tried in vain -for now-I gave up and got the BOL out fir it's maiden flight.Will post detials on the BOL thread.
Edmund2
Edmund2
#3268
ORIGINAL: Edmund2
As indicated last week I had to re-do the 4in1 adjustment. No problem getting the tail staedy but for the lov eof me I just can not get the gain rigth for it to stay on the same heigt when I use the rudder. After I tried in vain -for now- I gave up and got the BOL out fir it's maiden flight. Will post detials on the BOL thread.
I just plugged in my Tx (via softdog) into comp usb THEN started Clearview - and it is one of the options (on the same dropdown as "keyboard"), so I can't think of why you didn't have any success![] It seems you are doing ev'rthing correctly as far as I can tell...... Maybe just try it again[sm=50_50.gif]
My Lama4 can do continuous piruettes in either direction and not lose or gain ANY altitude - so that aspect of your 4in1 is another thing that I cannot understand........ Maybe Tony (barak1001) has some suggestions for you - PM him
P.S. [link=http://www.rcuniverse.com/forum/fb.asp?m=7314409]HERE[/link] is a link to the first page posts of this thread where the CW piroettes are similar to mine, the only diff. is my CCW piros are as fast as my CW ones & I don't lose any height!
#3269
On the drop down menu mine only displayed keyboard with no other option. Will try to first plug in the TX and then start Clearview.
Willtry the gain adjustment again and again......... and perhaps I will get some positive result. This was however aproblem from day 1. Everything else works fine,just very annoying not being able to fly the way itis supposed to. When I want to turn I either raise or lower it on order not to hit the roof or floor, alternatively I make a turn by moving the rudder bit by bit..
Edmund2
Edmund2
#3270
ORIGINAL: Edmund2
Will try the gain adjustment again and again......... and perhaps I will get some positive result. This was however a problem from day 1. Everything else works fine, just very annoying not being able to fly the way it is supposed to. When I want to turn I either raise or lower it on order not to hit the roof or floor, alternatively I make a turn by moving the rudder bit by bit..
As I indicated above, that is not the way it is supposed to be! Did you try PMing Tony for suggestions? He has a really nice Lama4 with plenty of experience.
Your Big Lama sounds wonderful I'm a little jealous That is the way your Lama4 should behave - but more "spritely".........
P.S. Reminder: when making "prop" adjustments on 4in1 you must un-plug & re-plug lipo for any change to take affect, but "gain" adjustments are fine - no un-plugging lipo necessary!
#3271
ORIGINAL: Edmund2
I will list the steps that I do (as I do them on a separate comp) - so you can follow them:
Plug softdog between Tx & comp usb.
Switch on Tx & lower throttle to bottom.
Start Clearview
Settings>Controller Setup(opens new window defaulting PPM)
Calibrate(centre throttle stick)>OK
Follow on-screen instructions re. moving both sticks to their extremes and toggling all switches>Accept
This should have you up & flying - then you choose which flying site (landscape) you want, and which model you would like to fly........it is that easy!!!
#3272
ORIGINAL: pgroom_68
Hey again Edmund,
ORIGINAL: Edmund2
I am doing the adjustment exactly as indicated on the post you directed me to. Got it almost right only once and that was before the big crash when it changed height very slightly on the turns. Tail adjustment is perfectlystill.
Edmund
#3273
ORIGINAL: Edmund2
I am doing the adjustment exactly as indicated on the post you directed me to. Got it almost right only once and that was before the big crash when it changed height very slightly on the turns. Tail adjustment is perfectly still.
...sorry, I was just enjoying myself flying a big Bell 47 in Clearview Wow - it is great when you Settings>Turn close up camera ON (option #11) & SHOW Tx sticks - just flipping about............(*sigh*)
P.S. Sometimes I just want to fly about in a simulator and not have a model - when you crash you have to fix it, but in the computer you just reset
Keep at it - do you mean [link=http://www.rcuniverse.com/forum/fb.asp?m=7350619]THIS[/link]?
If you take a short video, it would help us see & offer some help[sm=49_49.gif]
#3274
Will get somebody to take a video and then get some advice from you guys how to upload should I not get the adjustmentright this week. Think I saw something a few pages back on the thread how to do it. Would like to display my pictures in my hanger as well.
#3275
Hey guys, I been lurking around the site a while and have a question. Now don't get angry, but I DONOThave a v4. I have a v3. I couldn't find a current v3 thread so I decided to post here since the birds have their similarities. My question is regarding the servos. Well just one servo specifically. I have to replace it so I ordered a replacement one from boomtown. But I just noticed something. The pic of the servo on their site has two mounting holes or whatever they are. Well my esky servo only has one. And also the servo horn is a "T" shape and mine is just straight with 5 holes in it. One of the MAIN reason I ordered a new sero is to get the horn since I couldnt find the horn by itself. So, will the straight 5 hole horn come seperate with the new servo? And also, what do i do about that second tab with the hole? Cut it off? By the way if it makes a difference, the part # off my servo is EK2-0508 and the one I ordered is the same number. Any input?
