ORIGINAL: Edmund2
On the drop down menu mine only displayed keyboard with no other option. Will try to first plug in the TX and then start Clearview.
Will try the gain adjustment again and again......... and perhaps I will get some positive result. This was however a problem from day 1. Everything else works fine, just very annoying not being able to fly the way it is supposed to. When I want to turn I either raise or lower it on order not to hit the roof or floor, alternatively I make a turn by moving the rudder bit by bit..
Hey again Edmund,
As I indicated above, that is
not the way it is supposed to be! Did you try PMing Tony for suggestions? He has a really nice Lama4 with plenty of experience.
Your Big Lama sounds wonderful
I'm a little jealous
That is the way your Lama4 should behave - but more "spritely".........
Peter[sm=shades_smile.gif]
P.S. Reminder: when making "prop" adjustments on 4in1 you must un-plug & re-plug lipo for any change to take affect, but "gain" adjustments are fine
- no un-plugging lipo necessary!
