Exceed RC 1:5 Scale Maxstone Rock Crawler 2.4GHz Ready to Run RC Remote Control Radio
https://www.nitrorcx.com/51c877-maxs...n-rtr-24g.html
The 1:5 scale ready to run Exceed RC Max Stone Crawler was designed with bigger is better in mind. From the ground up, every detail was thought through to provide a excellent crawling platform level base kit to work with. Previously the only way to build a 1:5 scale sized rock crawler was to buy bits and pieces of several different kits here and there. This long and sometimes frustrating process could take as long as several months just to get the right parts together before you could even start the build. Now you can get a factory built chassis and be able to hit the rocks with your truck right out of the box.
The Rock Crawler embodies similar features to its smaller breeds. Multi-link suspension and axles provides articulation and power to all 4 wheels through locked axles and individual motors for each axle. This provides tremendous grip and torque and allows the truck to overcome any obstacle that it may meet its path. The links are adjustable so you can tune the crawlers stance, adjust its droop and characteristics for different types of terrain. An all aluminum chassis ensures rigidity and stiffness combined with durability. Oil filled, threaded, and adjustable shocks allow fine suspension tuning. A whole list of awesome features of this truck are listed below. This is Exceeds largest crawler to date and it is impressive!
Features:
Full ball bearing throughout whole vehicle
Multi-link suspension allows for smooth crawling
Four wheel driving provides tremendous grip for wheels
Alloy lower suspension link bars with captured ends
Solid axle mount provides protection for front/rear shaft
High precision ESC w/ reverse function
High precision 2 channel receiver
The 2.4Ghz RTR Exceed RC MaxStone chassis is lightweight and stiff.
Advanced battery mounting design.
Axle -Mounted steering servo.
Dual High-torque 540 motors.
Advanced tire pattern provides best grip and balance.
Unique Aluminum Alloy twin vertical plate chassis design
Revolutionary multi-link crawler suspension design
Heavy duty special harden axles and axle shafts
Advanced aluminum alloy suspension links
Advanced locked differentials four wheel drive design
High performance heavy duty rock crawling servo
High performance 7.2v 1800mah ni-mh battery.
Specifications:
Length: 840mm
Width: 436mm
Height: 350mm
Wheelbase: 620mm
Gear Ratio: 1:48.155
Motor: RC550*2
Servo: 15KG (Waterproof)
Battery: NI-MH 7.2V 3000mAh
Radio System: 2.4G
Wheels: 85*190mm
Waterproof Electronics
Package Includes:
MaxStone RC Rock Crawler (100% assembled)
7.2V 1800mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller Transmitter
Instruction Manual
Required to Run:
4 AA Batteries for Transmitter
Features:
Specifications:
Length: 840mm
Width: 436mm
Height: 350mm
Wheelbase: 620mm
Motor: RC550*2
Radio System: 2.4G
Wheels: 85*190mm
Package Includes:
Instruction Manual
Required to Run:
