MB 40 in action
I remember the Metkemeier brothers in old Aeromodeller magazines as a kid, and their team racers, and think they were in England at the World Champs in 1978 in FAI Speed and the US one a few years back. They are the M in MB.Pretty serious players. Kind of heroes, or pioneers at least, for me. Emil Rumpel too. Long time ago. That is a fast plane there.
Hallo speedfreaks,
here my 12 year old ( type one) MB 40 in action. Speakers max is a must. It is a symphonie.
https://youtu.be/F9QlhkHV-EY?list=PL...qnii_IL3dTBLN2
Regards Michael
Regards Michael
MB pylon engine
Hallo apseed,
to answer your question older or newer type MB engine. What is differnet.
The first MB 40 pylon engines where extremer, more powerfull but no easy to handle, often to difficult for the pylon racers.. So some userfriendly modifications came up.
The outlet port shape is complete different. On the older type much extremer.
The inlet porting ist also different, sometimes you have to use JB welt to modified type 1 to retuned in the size and shape as the new type, to became better handling.
Please see the pictures and compare what you see. Outside and inside a lot of different things you will see.
On all pistons you see the latest rod. This is the best. In the beginning you had a lot of problems with the rodbreaking, now this problem is solved.
I still use the old type for speed with better results but you need a lot of know how for consitend behavier on the engine.
Regards Michael
Regards Michael
Rob is testing new piston materials, but the current ones have a tendency to elongate/enlarge the hole for the piston pin at the rear end, closest to the exhaust.
I've developped a habit of checking the slop in the engine after every run, because obviously this situation deteriorates very quickly and very "destructively" .
This is of course when you run the engine hard, "easier" setups are also much easier on the piston.
I finished the world championship in Sweden on one piston, but I noticed from the behaviour of the engine at the starting line that it was on it's way out after about 7 flights. So total airtime on that piston was about 20 minutes, before it started to let go...and that was a good one.
Barrowed YS (10-13-2020)
Here is the original posted vid. bring the link together
posting the full link with no spaces just shows blank space here
Look what I had to do just to get it to show geez..
https://www.
youtube.
com/
watch?v=Gc4WGizn00w
https://www.
youtube.
com/
watch?v=Gc4WGizn00w
Hello sir, I got an f3d plane with MB40 engine installed from a friend. He just gave it to me. It’s brand new never flown before. He did have a problem to start that engine. I believe he didn’t know how to start it neither me!!
If someone could help me and give me an idea how to start it, I would really appreciate that.
These engines are very temperamental. I would never give advice on how to operate them, but I've seen enough of
them flown at the last two US team trials to know that they can be a hand full, so by all means seek advice. What
would be best, would for you to hook up with someone who can show you how they should be operated. There was
a US team selection event last October that selected the team to represent the US at the next world championships.
Unfortunately the world champ race has been postponed until next year. Just something as simple as the fuel is a
challenge, since these engines are set up for 80/20 alcohol and oil. I could share more cautionary tales, but suffice
to say if you want to have hours of frustration go it alone. Good luck, and let us know if you have success. By the
way, where are you located, because you might be near help, and not know it.
wing13z (03-12-2021)
Thanks for your replay. To be honest, I did not start the engine yet. I can see that carburator it doesn’t need throttle servo which means it’s going to operate on full throttle all the time. The tricky think is how to start that engine? Is there any technique or procedure?
I did watch a few videos on the YouTube and it looks like that’s engine has to start rich on fuel!! Then you would adjust the needle and fly it.
But the tricky thing as I mentioned earlier how to get it to start 😂 am I missing something there?
I was searching for a manual for that engine but couldn’t find anything!!
I used to live in Florida but I’m now overseas doing some work.
Get spare glow plugs (they are not standard plugs).
Get an adjustable glow driver that has the power to really light those plugs up, a standard glow driver will not work.
Get a starter that spins fast, 4S lipo on a standard 12v starter works.
Make sure the fuel shut-off works.
Get or make a fueling syringe, the plane will have a bladder tank.
Get someone to hold that plane, and hold it tight.
Open the needle 4 turns or so, open the shut-off.
Close the tuned pipe off with your finger, and apply starter for 2 seconds to prime the engine.
Turn on glow, plugs should glow bright orange.
Now comes the part where you need 3 hands :
With one hand ready at the stinger of the pipe, apply the starter.
When the engine fires, and gets on the pipe immediatly, be ready to close the needle a couple of turns: when the pipe builds pressure, it will drown the engine at a rich setting.
If it fires, but sounds like it runs of the prime, give it more fuel by intermittantly closing off the tuned pipe with your finger.
Beware though, if the engine decides to pipe up while you have your finger on the stinger, the hot exhaust WILL burn you in an instant.
An afternoon of engine testing will leave you with a nice Audi mark on your finger.
If the engine fires but can't get "on the pipe", you will have to work the needle and the pipe stinger at the same time.
It helps if you run a short prop, so get some spares to experiment.
