Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
tuned pipe question
tuned pipe question
Old 06-15-2009, 12:38 PM
mk1spitfire
mk1spitfire's Avatar
Default tuned pipe question
For the shear hell of it, Do you think two smaller pipes couldbe used instead of one.
The custom header spitting into two.
Would this work?
Old 06-15-2009, 12:49 PM
MJD
MJD's Avatar
Default RE: tuned pipe question
ORIGINAL: mk1spitfire
For the shear hell of it, Do you think two smaller pipes could be used instead of one.
Would this work?
I think:
1. It would probably work to some degree
2. It would likely suffer from a relative lack of efficiency, extra weight, cost, complexity (the last three are obvious, I know)
3. It has no practical purpose other than to make something look cool, which in itself is okay if that turns your crank
Maybe a header that splits into 6 exhaust outlets, each into one of 6 tuned pipes all tuned to different rpm ranges.. the no moving part supercharger!
MJD
Old 06-15-2009, 02:55 PM
mk1spitfire
Ha...
each pipe to cover the rpm range, like it!!!
The cool factor yes. The weight, i duno, could two pipes equal 1?
Would the sound be any better?
I've often thought if the signature tune of the engine is influenced by the pipe and what additions could be added to create further deeper basser resonance..!! even an airwhistle or something to manipulate the audable sound frequencies for maximum sound blasting....!!!
I want an engine like this.....!!!
Old 06-15-2009, 05:47 PM
combatpigg
combatpigg's Avatar
If you played with a pair of .15 pipes on a .35, you might find something of interest?
