ORIGINAL: mk1spitfire
For the shear hell of it, Do you think two smaller pipes could be used instead of one.
The custom header spitting into two.
Would this work?</p>
I think:
1. It would probably work to some degree
2. It would likely suffer from a relative lack of efficiency, extra weight, cost, complexity (the last three are obvious, I know)
3. It has no practical purpose other than to make something look cool, which in itself is okay if that turns your crank
Maybe a header that splits into 6 exhaust outlets, each into one of 6 tuned pipes all tuned to different rpm ranges.. the no moving part supercharger!
MJD
