F20 tigershark ...low pass
HI brothers
here is my F20 tigershark on youtube
http://www.youtube.com/watch?v=oUMu00Vj12U
I wanna you to advice me to get it faster , either by changing the engine or any other modifications
as to know , it has a 51G supertiger engine with a tuned pipe of Macs
running on a 10% byron fuel + 10x 7 prop + 2.4 GHz futaba 6ch system
thanks in advance
thanks in advance
My Feedback: (12)
RE: F20 tigershark ...low pass
Try a 10-6 or 10-5 prop on it to achieve a higher RPM. The ST G-51 is rated at 1.48hp @15,500 rpm. A 10-7 prop may be too much for it.
Start with the recommended prop (10-6) and the original muffler and take an rpm reading. If the engine is new you may need to fly it for a while to make sure it's broken in. You should be in the 11k - 12k rpm range. If not, go to a 10-5 prop. Once you are satisfied, then install the tuned pipe and adjust the length until reaching a max rpm. The tuned pipe should boost rpm around 1k rpm or so.
If this is still not fast enough for you, then it's time for a new engine. OS 55AX may be worth a try.
Good Luck!
Good Luck!
