Blizzard from Corvidae.net
I've chosen the Blizzard .15 as a new project because I'd had a hot MVVS .15 GFR around, waiting for a model as this. I was looking for something quick and with a sleek fiberglass fuse. Now it's really gotten time to begin with building because I had it laying around for over a year. I promised to make a nice building report, and here it is I believe. ;)
The package arrives http://www.rc-cropduster.com/users/j...lizzard_01.jpg http://www.rc-cropduster.com/users/j...lizzard_02.jpg http://www.rc-cropduster.com/users/j...lizzard_03.jpg All the components on display. Included is the CNC-pack. Very nice. http://www.rc-cropduster.com/users/j...lizzard_04.jpg The MVVS .15 GFR with venturi. M+R engine was also an option, especially as you've seen the price. A .15 M+R engine does cost €90,- (about $100,-) in Germany. The M+R is a modified .15 Rossi Fire, which is very hot! But the MVVS was lying around, so there it is. ;) Note the outstanding quality, great value for money. I also like the blue anodized material. http://www.rc-cropduster.com/users/j...lizzard_05.jpg The leading edge and wingtips glued to the wing with D3 glue (for wood, also works well with styropor/foam) http://www.rc-cropduster.com/users/j...lizzard_06.jpg http://www.rc-cropduster.com/users/j...lizzard_07.jpg The wingtips are also attached. http://www.rc-cropduster.com/users/j...lizzard_08.jpg http://www.rc-cropduster.com/users/j...lizzard_09.jpg http://www.rc-cropduster.com/users/j...lizzard_10.jpg http://www.rc-cropduster.com/users/j...lizzard_11.jpg Sanding the wings with a 3° angle for joining together. http://www.rc-cropduster.com/users/j...lizzard_12.jpg 12mm spacing under each wingtip. http://www.rc-cropduster.com/users/j...lizzard_13.jpg http://www.rc-cropduster.com/users/j...lizzard_14.jpg Now waiting until the glue is cured. http://www.rc-cropduster.com/users/j...lizzard_15.jpg 3x Hitec HS-85MG for the Blizzard. http://www.rc-cropduster.com/users/j...lizzard_16.jpg Made a small gap for the servo cables. There's a slot prepared in the foam to make it very easy. http://www.rc-cropduster.com/users/j...lizzard_17.jpg I did cut a gap for the servos. Mounting brackets sawed off to reduce the mounting space. http://www.rc-cropduster.com/users/j...lizzard_18.jpg Both gaps are finished. http://www.rc-cropduster.com/users/j...lizzard_19.jpg Cut a slot to fit the wing spar. http://www.rc-cropduster.com/users/j...lizzard_20.jpg Removing styropor / foam. http://www.rc-cropduster.com/users/j...lizzard_21.jpg Glued the wing spar into place. http://www.rc-cropduster.com/users/j...lizzard_22.jpg Detail photo. http://www.rc-cropduster.com/users/j...lizzard_23.jpg Cut out the ailerons. http://www.rc-cropduster.com/users/j...lizzard_24.jpg Peace of heavy glass for reinforcement. http://www.rc-cropduster.com/users/j...lizzard_25.jpg Entirely covered the wing with 25 gram glass. Waiting for the G4 to set in and dry. http://www.rc-cropduster.com/users/j...lizzard_26.jpg Removing unnecessary glass with a peace of sanding paper. http://www.rc-cropduster.com/users/j...lizzard_27.jpg Finish all the edges to give a smooth result. http://www.rc-cropduster.com/users/j...lizzard_28.jpg Reinforcing the upper side of the wing. http://www.rc-cropduster.com/users/j...lizzard_29.jpg Wing reinforcement together with a peace of plywood for the wing-bolt. http://www.rc-cropduster.com/users/j...lizzard_30.jpg Smooth! http://www.rc-cropduster.com/users/j...lizzard_31.jpg http://www.rc-cropduster.com/users/j...lizzard_32.jpg Sanded the stabilizer in shape and covered with glass. http://www.rc-cropduster.com/users/j...lizzard_33.jpg http://www.rc-cropduster.com/users/j...lizzard_34.jpg http://www.rc-cropduster.com/users/j...lizzard_35.jpg http://www.rc-cropduster.com/users/j...lizzard_36.jpg http://www.rc-cropduster.com/users/j...lizzard_37.jpg Measured the place for the hole and drilled. http://www.rc-cropduster.com/users/j...lizzard_38.jpg 5mm carbon wing dowel glued with epoxy. http://www.rc-cropduster.com/users/j...lizzard_39.jpg Plate to accommodate the blind nut. http://www.rc-cropduster.com/users/j...lizzard_40.jpg http://www.rc-cropduster.com/users/j...lizzard_41.jpg http://www.rc-cropduster.com/users/j...lizzard_42.jpg http://www.rc-cropduster.com/users/j...lizzard_43.jpg Used a pipe wrench to force the blind nut into the plywood. http://www.rc-cropduster.com/users/j...lizzard_44.jpg Peace of scrap ply to ensure it isn't damaging the fuse. http://www.rc-cropduster.com/users/j...lizzard_45.jpg Complete view of the project. http://www.rc-cropduster.com/users/j...lizzard_46.jpg http://www.rc-cropduster.com/users/j...lizzard_47.jpg http://www.rc-cropduster.com/users/j...lizzard_48.jpg http://www.rc-cropduster.com/users/j...lizzard_49.jpg http://www.rc-cropduster.com/users/j...lizzard_50.jpg http://www.rc-cropduster.com/users/j...lizzard_51.jpg http://www.rc-cropduster.com/users/j...lizzard_52.jpg http://www.rc-cropduster.com/users/j...lizzard_53.jpg Together with the Stiletto. http://www.rc-cropduster.com/users/j...lizzard_54.jpg Engine and firewall fixed. Needed to modify the firewall and engine bracket to clear the rear exhaust. http://www.rc-cropduster.com/users/j...lizzard_55.jpg http://www.rc-cropduster.com/users/j...lizzard_56.jpg Still quite a lot of space between the wing and exhaust. http://www.rc-cropduster.com/users/j...lizzard_57.jpg Joins nice. http://www.rc-cropduster.com/users/j...lizzard_58.jpg Cutting a gap with the Dremel. Should be all covered up eventually. http://www.rc-cropduster.com/users/j...lizzard_59.jpg Glas gesopt met 30 minuten epoxy. Heeft ongeveer al de juiste vorm, eventueel later met verfstripper bijwerken. Soaked glass with 30 minutes epoxy resin. Has almost the right shape, maybe needs to be modified with heat gun. http://www.rc-cropduster.com/users/j...lizzard_60.jpg Added balsa to accommodate the hinges. The PU glue is foaming great as you can see. http://www.rc-cropduster.com/users/j...lizzard_61.jpg I could modify the epoxy plate that I soaked with my bare hands because it was still soft enough. Forced it into place and glued it with 30 minutes epoxy and micro balloons. Satisfied with the result but needs to be sanded afterwards. I'll paint it with some metalic blue paint. http://www.rc-cropduster.com/users/j...lizzard_62.jpg Peace of hard balsa glued on the aileron to add more strength for the rudderhorn. http://www.rc-cropduster.com/users/j...lizzard_63.jpg Only the control surfaces need to be covered with glass, but the model is almost finished! http://www.rc-cropduster.com/users/j...lizzard_64.jpg Viewed from the top. http://www.rc-cropduster.com/users/j...lizzard_65.jpg The color scheme I'd had in mind is inspired by a Shockflyer color scheme. I believe it's quite nice because it is very simple and shouldn't be a hard job to paint. I wanted to keep the color scheme simple since I don't have much experience with paint brushing effects. I want to maintain the clear wood instead of the white depron. Should look nice. http://www.rc-cropduster.com/users/j...olorscheme.jpg Added some glass to the ailerons. http://www.rc-cropduster.com/users/j...lizzard_66.jpg http://www.rc-cropduster.com/users/j...lizzard_67.jpg To be continued! ;) |
RE: Blizzard from Corvidae.net
Just one question...: why the hell did you pick the MVVS over the Russian Rossi copy? I mean, the little MVVS is great value if you make a cost/power balance... But if you're going for all out speed, you're better off with an engine like the M+R in the long run, because the MVVS simply lacks brute power/rpm capabilities in stock form...
Yes I know. ;) But it was lying around here, so I chose the MVVS. Maybe I'll order the M+R later on but first the Blizzard has got to go airborne! All the control surfaces are covered with glass. Only thing resting is spraying paint on the wing and stab.
Rudeboy,
Do you have a website, contact point for that engine your talking about.. Smitty |
Hello,
Very nice plane ! Why did you removed Cylinder head ? Did you liked this 2.5 ccm MVVS, is it any god and is it really more poverfull than standard OS / Magnum 2.5 ccm engines ? How they made this shiny metallic fuselage, is it gelcoat or paint ? You should make video of first flight :) Kristijan |
Thanks! ;) I already had the MVVS and I believe it is a good match. Die MVVS has a higher RPM output compared with the OS (I also have the OS .15 CV-A) and Magnum engines, which are more for high torque applications. But beside the higher RPM, I do like the rear exhaust also. Gives a very sleek airframe and reduces drag of course. While building I'd completely stripped the engine to make it easy to fit inside the fuse. It also makes it easier to modify the gap made for the engine and reduces any chance of damaging the blue anodized cylinder head.
The fuse is quite a piece of art. Underneath you can see how the Stiletto fuse is made, for the Blizzard was the same construction method used. The moulds are sprayed with paint and glitter flocks before adding any epoxy resin and glass. It gives a very nice result as you can see. The moulds with paint sprayed, ready to add glass and carbon. http://www.rc-cropduster.com/users/j...tiletto_01.jpg Both sides are soaked in epoxy resin, now the moulds can be closed. http://www.rc-cropduster.com/users/j...tiletto_02.jpg Feels like Christmas, opening the moulds after 24 hours hardening. http://www.rc-cropduster.com/users/j...tiletto_03.jpg The cowl for the tuned pipe to reduce drag. http://www.rc-cropduster.com/users/j...tiletto_04.jpg The fuselage is taken out of the template. Edges need to be finished with a Dremel cutter and gets a warm bad of water to remove PVA and wax. http://www.rc-cropduster.com/users/j...tiletto_05.jpg http://www.rc-cropduster.com/users/j...tiletto_06.jpg Jorrit's Stiletto. Quite a hell to make with the silver glitter material. After 5 minutes of laminating you lose track of what you're doing. http://www.rc-cropduster.com/users/j...tiletto_10.jpg http://www.rc-cropduster.com/users/j...tiletto_11.jpg The next day the epoxy resin is cured. http://www.rc-cropduster.com/users/j...tiletto_14.jpg http://www.rc-cropduster.com/users/j...tiletto_15.jpg http://www.rc-cropduster.com/users/j...tiletto_16.jpg I'm not going for the M+R on the short term by the way. The OS 50 SX-H from my Raptor 50 needs to be replaced. It did run to hot, so I'm going to buy the 50 Hyper. And since I need to spread my costs I'll stick with the MVVS. |
Hello j0rrit,
throw that stinkin' Master Airscrew into the bin and get you a black Graupner Speed Prop 6.5x6.5 ;) To be then shortened to 5.5" in diameter. That makes this little MVVS 2.5 really come alive - if you use a full length tuned pipe (MACS 1110 for instance). The stock black magic muffler is too restrictive. The MACS Pipe length between glow plug and biggest part of the pipe should be set about 21 to 23 cm. You need to widen the MVVS speed venturi carb up to 6 mm of inner diameter. Presupposition is that you MUST increase engine exhaust timing up to 170 degrees. Then 25 thousand rpm in flight will be no problem. That makes approx 140 mph with your Blizzard airframe... Regards slomo P.S. The conrod of the UCTKAM .15 = MDS .15 Speed Pylon (or M+R .15 engine rpectively) does not feature a bronze bushing on both ends - just to remember that. :eek: |
Oh, I forgot to mention that any plastic spinner can be very dangerous at rpms exceeding 18 thousand. Highly recommended are precision CNC machined aluminum spinners by Truturn.com (can be ordered through braeckman.de for instance)
The Master Airscrew was only mounted for display purposes. I had an APC prop in mind, but I'll consider using the Graupner speed prop. Thanks for the tip! I've good experiences with the plastic click-on spinners from Carl Goldberg, unless we're exceeding the rpm-limit. I know. Maybe I'll mount an aluminum spinner eventually, but with the stock engine it's no problem. I've ordered two TruTurn 1-3/4" spinners for the Stiletto's though.
I spoke a Line-Control speed race enthusiast last time and he's using the same MVVS as I do. He'd manage to tune it with a easy solution in my opinion. Using a shimmy of 0,5mm under the edge of the cylinder, the timing is adjusted to 162°. The new timing should already be a big improvement. To keep the compression the same you need to remove the 0,5mm from the top of the cylinder head. That's a job I could do with ease at school. In combination with a APC 6,5x6,5 and 6mm venturi (like you advised also) it was quite an improvement. I'll check the internet for a MACS 1110, I'm curious about the possibilities. ;) |
ORIGINAL: j0rrit I had an APC prop in mind, but I'll consider using the Graupner speed prop. ... Using a shimmy of 0,5mm under the edge of the cylinder... There are many more measures to successfully fine tune the peak rpm of a two stroke engine. But the by far most important one is a matching exhaust ( + liner timing) adjustment. So a correctly set non-muffled full length pipe is a must… |
I messed around a little with an MVVS .15 last year... here are the stock timings I measured on mine:
exhaust 160° transfers 116° boost 110° induction 180° starting 50° ABDC The head was almost at a whopping 0.5mm [X(] Slowmo, 0.35mm still seems rather a big gap to me... I was going to go to about 0.20-0.25mm, maybe even less and increase the head volume a little to allow more nitro (don't know about that part yet without more testing). Why do you suggest such a wide squish clearance? There's definitely room for improvement on this thing. |
Hello Rudeboy, Yes, I do run considerable smaller head clearance on other 2.5 cc speed engines without problems - using FAI fuel. ORIGINAL: Rudeboy Why do you suggest such a wide squish clearance? Compared to their price these small MVVS engines (2.5 and 3.5 cc) offer great value for the buck. With only little effort you can make them scream - nice for reasonably priced speed planes. With a fully cowled engine+pipe the Blizzard will be a lot faster! Regards slomo P.S For very satisfying performance of 2.5 to 3.5 cc speed engines, meaning above 35 thousand rpm in-flight, you must use conical glow plugs. |
Well, the building continues. :)
I used a sort of bondo for priming which can be brushed or rolled on. That doesn't give a smooth result, therefore I added some paint thinner and sprayed it on with a spray-canister which can be pressurized. http://www.rc-cropduster.com/users/j...lizzard_70.jpg http://www.rc-cropduster.com/users/j...lizzard_71.jpg |
