Futaba 9C with AnyLink Module NEED to remove RF module too?
My Feedback: (13)
1 Post
I have a Futaba 9C (not Super).
With an AnyLink module plugged into the trainer port do I have to remove the Futaba RF module from back of the transmitter to avoid potential damage due to a collapsed antenna?
If I have to remove the RF module each time I use the AnyLink system is this a wear problem to the Futaba RF module or the port connections in the back of the transmitter?
Garyss
Garyss
Per the instructions for the AnyLink, yes, you need to remove the module.
http://manuals.hobbico.com/tac/tacj2000-manual-v2.pdf
When removing the module, be carefull to pull it straight out and do not use undue force when inserting it, just simply snap it back in securely. But you would have to remove and insert it quite a lot to cause any significant wear on the 9Cs connectors.
Sincerely,Krysta
Product Development & Support Specialist
Futaba Service Center USA
Sincerely,Krysta
