Telemetry Logic 18mz
I'd like to setup some form of very basic logic on my 18mz to activate the warning function. I'm trying to set up a low RPM alarm for a turbine, but I would like the alarm to function ONLY when I have the gear in the retracted position. The problem I have is that the alarm is going at all times when the turbine is not running and the plane is on the ground. I couldn't find any setting that would assign a switch to the "INH/OFF" setting.
There is no way to use logic to control the telemetry alarms. However, you can assign a switch to silence the alarm.
In LINKAGE->TELEMETRY
You will see Alarm ON/OFF switch. Assign a switch there.
