9C Voltage Readout
9C Voltage Readout
When my 9C indicates 10.2 volts, my Tower MKII ESV reads 9.8 volts. Other than assuming that the ESV is wrong, could there be any other reasons for the discrepancy?
RE: 9C Voltage Readout
Without seeing it, this would only be a guess, but the lead from the transmitter to the ESV may be damaged or corroded. Also the connecors on the ends of the lead may have cold or poor solder joints.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
ORIGINAL: SteveGB
Anybody from Futaba??
