FP-R129DP receiver 6Volt Battery
AZ
Hi I have 3 FP-R129DP receivers and I need to know if I can uses 6V battery with them and if yes do I need a voltage regulator for the servos they are futaba S9402
Thanks in advance Tom
RE: FP-R129DP receiver 6Volt Battery
Bill,
Does this apply to all Futaba receivers? Do all the receivers have a regulator, and if so, if one is using a 6 volt battery that is regulated down to 4.8 volt at the Rx side, how much voltage do the servos see?
