9C compatible small Recieivers.....
MO
Hello,
Just curious if there is a list somewhere, or if anyone has any insight on the compatibility of smaller recieivers that work with a 9C synthesizer transmitter. I have a good deal of 127DF recievers on most of my planes, but I am putting together a smaller F-16 Ducted fan that only requires 3 channels and a small reciever with good range. I have considered the R124F and R114F but I am concerned with the short range (or should I be?). Any thoughts or ideas? It doesn't have to be a futaba RX, but I dont mind either way as long as it works with my 9C Sythesized TX. Thanks!
Jetnfast
Jetnfast
CO
RE: 9C compatible small Recieivers.....
Any receiver that wil work with Futab transmitters will work work with the your 9C. The Berg 4(from castle Creations) or Hitec Electron 6 (Tower) for instance. Just make sure you dial in a synthesized frequency to match the crystal in the receiver. I would stick with dual conversion receivers if I were you. (the Berg excepted.)
There is no "list". Futaba does have micro receivers that will work with all of their other systems. We can't speak for non-Futaba makers. Some of them work and some don't...there isn't a list. You'd need to check with those vendors if you decide to use non-Futaba receivers.
The Futaba micro receivers are:
FUTL0438 R124F ULTRA MICRO FM RX 72 LOW US$49.99
FUTL0439 R124F ULTRA MICRO FM RX 72 HI US$49.99
FUTL0641 R156F FM 72MHZ MICRO W/O XTL US$79.99
FUTL7626 R616FFM 2.4GHZ FASST PF RX 6CH US$89.99
All of these receivers will work nicely with your Futaba transmitter.
MO
Bax,
Thanks for the reply, I appreciate the info. Those were the recievers I was considering that are made by futaba. Thanks Again.
Aaron
Aaron
IL
You've probably already purchased a receiver by now, but I'll throw out the name of Berg receivers. I've used several of them, and have been quite satisfied. Plus these are now available through Tower.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLBY8&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLBY8&P=ML[/link]
Kerry
Kerry
