OS GT33 33cc gasser
#401
My Feedback: (12)
ON, CANADA
RE: OS GT33 33cc gasser
Thanx for posting your prop no's Bob. I am planing on using the 20x8 xroar as well. I just recieved mine a couple af days ago and it looks great. I comapred it to a new DL 20 and DL 50 that I have and it is very easy to see that the OS is made to a much higher standard just by looking at them. I will be putting mine in a Great Planes Patty Wagstaff so I will probably be on the upper limit for good performance with the 33cc. I have another Patty with a 50cc that I did a lot to keep the weight down to 15.0lbs. I should come in at 13.5 to 14 lbs with this one. Do you know how much your Yak weighs Bob?
#403
My Feedback: (10)
TX
Flew a few more flights today. My GT33 has put all of my gassers to shame. That includes DA, DLE, MVVS, Zenoah, BME, Brison, etc. It's smooth, powerful, starts in less than 3 flips, idles LOW, super quiet, accelerates very well, very little shake/vibration. What more can I say?
My GP Yak AUW is 13lbs 6oz. Tweaked the needles some today. Xoar 20x8 was 1550 idle, 6400 steady, 6500 peak. Falcon 20x8 was 1550 idle, 6700 steady, 6850 peak. The Falcon pulled like a tractor, revved like a Ferrari, and outperformed the Xoar. Got my Falcon from justmodelprops dot com.
#404
ORIGINAL: coronabob
#405
My Feedback: (12)
ON, CANADA
Great prop info Bob. Looks like the xroar 20x8 is a little too much for it. I like the looks of the xroar sword props so I might try a 19x8 or a 20x8 carbon falcon. In Canada the same guy sells xroar and falcon props. It looks like the 33cc Patty will weigh about 1/2 to 1lb more than your Yak so vertical performance should be close to your Yak. I am looking forward to my next Patty build and using some of the new tech today to keep the weight down that was not available when I built my 50cc Patty.
#406
ORIGINAL: seagull extra
BTW- the engine takes around 50 flights to fully loosen up. You'll be able to tell when you turn it over; bearings and ring will give practically no resistance. You should pick up another 100-150 rpm give or take. But even tight, the engine is a stump puller; I really don't think you will have any issue hauling a 15 pounder around with this engine.....
#407
My Feedback: (10)
TX
A couple of shots our club's instructor/safety officer, James Lemon, took of my GT33 powered GP Yak. The back drop is some of the facility at the Johnson Space Center in Houston.
#408
ORIGINAL: coronabob
I disliked the colours my own yak came in that much i peeled it all off and re-covered. the first pic is my yak next to a friends which has the original colours.
#409
ORIGINAL: coronabob
#410
ORIGINAL: coronabob
#412
My Feedback: (10)
TX
Copied and pasted from my previous post:
Flew a few more flights today. My GT33 has put all of my gassers to shame. That includes DA, DLE, MVVS, Zenoah, 3W, BME, Brison, etc. It's smooth, powerful, starts in less than 3 flips, idles LOW, super quiet, accelerates very well, very little shake/vibration. What more can I say?
The GT33 makes my two DLE30s look bad. I paid $360 for mine with discount from Tower. The muffler alone is worth the extra $50 over the new DLE 35.
#413
ORIGINAL: coronabob
#414
My Feedback: (10)
TX
MTK,
The JSC club boasts a brand new black top runway and it is LONG. Keep us in mind when you come visiting. I can get you a pass onto our field.
#415
ORIGINAL: coronabob
MTK,
MTK,
#416
Anyone have a link or some good instructions on first time tuning on a os 33, this is my first gas motor.
I just finished my waco, have had it on a scale yet but I think it's right around 15lbs.
#418
My Feedback: (10)
TX
ORIGINAL: rstekeur
[img][/img]
[img][/img]
It pulled fuel almost immediately. After three flips at full choke, full open throttle, ignition off I turned on the ignition and a couple of fast flips it started backwards. I opened the throttle a little and that helped eliminate most of the backwards starting. I did not change the needles and flew a couple of flights. Started adjusting the needles and got it rich mostly. It still ran ok at rich settings. I leaned out both the low and high after 4 flights.
I am now getting 7100 wide open with excellent throttle response on 20X8 Falcon wood. The handling could not be better and the sound superb. At idle, it sounds like a clean combustible pump that it is. I think it is unique in that the throttle response past idle can be compared to having a large negative expo setting. I have to move the stick quite a bit to get the same speed I would with other gas engines. It might be my linkage, which I do need to check. I might have to dial in some positive expo on my 12FG to see if I can get a linear throttle response.
I plan on buying another one. At $360 at Tower with club member's discount it is a steal in my opinion. Full price is $420 compared with an OS 120 special (glow) at $330.
#419
That's how I got mine with the discount plus there was a $30 rebate that I sent in. That's about where the price should be. I have a dle20 and the OS looks like a nicer quality motor. When I started it up last sunday going to full throttle the rpm would start to drop and it was getting late so I put it off untill this weekend.
#420
CoronaBob nailed it...
One thing I will add is that low speed needle setting when leaned too far (true with most any gassie eventho the engine idles fine) will cause the engine to die lean when advancing throttle quickly. I found it to be a very reliable check for lean LS needle. When you find that point, it takes a little more than 1/8 turn rich to transition clean
As CoronaBob stated, to start, get the engine set to high idle to minimize reverse starts. It starts by hand fine. Except I use sharp APC props on mine so a Dynatron starter does the job for me. I'm turning the Dynatron with 6S lipo, 2300 ma. One charge lasts about 6 months
#421
SC
Coronabob, many guys are putting dle 55 into that YAK. Does the OS GT33 have enough juice to fly 3d or just sport? Also, did you have to add nose weight with this engine?
#423
Does anyone have source for prop bushings (metal) to make up the difference between the GT33 8mm dia. prop shaft and the more common 10mm hole in most gas props like Xoar, Mejzlik, etc??
Thanks!
Thanks!
#424
I asked the same thing and was told to wrap a few wraps of tape so it's snug enough. Thats what I did, and it's been fine. If you find any bushings, please post a link.
#425
ORIGINAL: Ken Cz
Thanks!
Thanks!
Give Matt a call at the Prop Shop. He's been able to fix me up with an adapter bushing a number of times.
Where do you fly at ?
Joe M.
