WJ71 THROTTLE ARM PNP
My Feedback: (12)
I have had many people wanting an easier method of connecting a throttle linkage to the WJ71 Walbro carb so your problems have been resolved. Parts are top notch and machined right here in the USA by one of the best.
www.vital-rc.com
This arm will retain factory throttle/choke release but I recommend removing throttle stop/idle set.
Connection detail:
Pin from arm goes into small hole on carb stock arm.
Threaded nut goes into backside of stock carb arm and is attached with supplied screwed.
2 open threaded connections are for ball link attachment, you pick which one works best for you.
Price will be $12 plus shipping for the arm kit.
Thanks Guys, I hope this makes it alittle easier for you installing your JC120. If you need an easier choke setup I suggest using Spot on Choke Arms.
Install pics Below.
www.vital-rc.com
RE: WJ71 THROTTLE ARM PNP
Nice fix, I find the engine manufacturer at fault here. You purchase a purpose build Model Aircraft engine with a carb right off the chain saw, modifiactions are necessary right out of the box. It's nice some manufactures like DA and D&Bhave added those at the factory, I'm sure there are others.
We agree but, for example. the DLE and DLA twins are equipped with knock-off clones of the Tilotson carb. I replaced the one on my DLE111 with a genuine Walbro WJ-71. I made my own throttle arm from G10 but had this product been available at the time I may have purchased one.
