Prop Hub Clearance
IL
Prop Hub Clearance
Not completely engine related, but I'm sure you are the right people to ask....
The distance from the firewall to the front of my cowling opening is 5.75" - 5.825" ish. So if getting, say, a Syssa, which allows you to order the engine with several different sized 'setups', would 6" firewall-to- prop hub be enough clearance, or do I want to go to 6.25"?
Thanks!
Thanks!
