power for engine and recvier
My Feedback: (19)
You could just use a "Y" and with modern radios, it would probably work OK. But there are better ways to go. If you want to use one battery, i would recommend using an Ignition Battery Eliminator Circuit or (IBEC). Here is one of the most common brands:
http://www.tech-aero.net/ultra-ibec
It provides some isolation between the receiver and ignition, it provides a means to kill the engine from the receiver and it has a built in voltage regulator with short circuit protection .... plus other features. These are well proven devices. Other brands are available but this is my personal preference because of its versatility and ease of use. There are very few reports of problems with these units.
AZ
My Feedback: (19)
True but the IBEC replaces other parts that can also fail. I held your opinions about the IBEC for a very long time but decided to try the Tech Aero unit when I heard such positive reports about it's performance. I have been more than pleased and now have them in every gas powered plane I own. I'm in my third season using them now with zero problems. I had more problems than that maintaining separate ignition batteries and switches. So for me, the reliability factor is a trade off for convenience with some added safety features (cut off) and the Tech Aero has not disappointed me in any way.
I could say the same about the Rcexl opti switch and my experiences with it. After several seasons on several different planes, have found them to be reliable, functional, and 1/2 the cost of the TA switch. The only advantage the TA switch offers is the BEC feature comes standard. The logic behind Rcexl's strategy to supply them without that, preferring DIY Bec instructions instead, makes no sense at all....
Regarding the OP's question, agree there are better ways.
AZ
But its your money. I guess you can spend it anyway you like.
Rye, yes you can just use a Y and it will work just fine with the 6v and DLE ignition. I am as Truckracer and use the Tech-Aero for the same reasons as he stated.
I would also like to ask,Why are others argueing with anyone's opinion? Seriously, it is an opinion and can be taken or left at the OP's discretion. It seems these days so many argue another's opinion than simply offer up theirs as if they are not sure enough on their opinion to let it stand.
If you like or don't like certain thing's go your own way but have the confidence in your way to not argue against another's.
Old habits die hard, and the idea of using only two separate batteries for ignition and radio is one of them. I've been flying an airplane with one battery for ignition and the radio, and no IBEC, for two years now with zero problems. I agree a better setup would be to use the Tech Aero unit, but at $40.00 they are a bit pricey it seems to me. (But I'm pretty cheap sometimes!)
AV8TOR
AV8TOR
All of my plane's are set-up with one battery. Well, the normal one's anyway, the giant Pitts has three. I do use the IBEC though but that is my choice. Is it a necessity absolutely not, I did not use them to start with. But one day my throttle servo stuck 3/4 open and it would have been really nice to have been able to shut it off rather than fly around for forty five minutes. I went with the IBEC and reduced my tank size as well. The tank size was another carry over from the Nitro days and was severely oversized for gas.
My Feedback: (19)
I have always supported that we engage in a hobby where there are many ways of doing something right. Different perhaps, but still right for the individual. Most of us are also smart enough to know when our way is less than desirable or adequate so we change our ways when necessary. And ..... is it just a hobby!
My Feedback: (13)
OH
I make my own a123 packs up and just solder in two output leads for the RX and ignition,but I am using 2.4.The only reason I don't use a IBEC is, one more part that could go bad... But the biggest is I am to CHEAP.
AZ
If you look at the initial post he says his way is a better way. Its not.
1)Its more expensive.
2) Its less reliable
3) It wastes battery power.
On the plus side, it includes an engine shut off but this $10 item will provide that if you think you need it.
https://www.pololu.com/product/2804
I helped Ed develop the TA IBEC 6 years ago. It has gone through a couple revisions to improve the RFI filtering even more than the previous versions to handle 72 MHz systems that were at least 20 years old. My 10x on 72 Meg and 12X on 2.4 Gig didn't have any issue running the original prototype unit that we hand wired. It still works fine today with its older filtering modules IN MY radios. I spread the good news and from the look of things some heard.
The IBEC is no more or less prone to failure than any second battery and second switch. I could argue that the battery is the most failure prone device on a plane and the second switch certainly is another source of possible problems, but I won't. You make your own judgements there. The IBEC does not use a second switch; it's one switch that powers the airborne system, period. If that fails, your plane is in deep yogurt....
No, the TA IBEC does not ""waste"" battery power of any significance; your CDI will use whatever it needs to drive ignition. Whether that comes from a second battery or from an IBEC is irrelevant to the CDI and the spark plug. It sips a very small amount of battery power to filter RFI noise on the order of about 0.05% of what the CDI needs to drive the plug
An 1800 ma Lipo or Lion pack will run the CDI and the RX on a typical 6-7 servo 10-15 lb plane set-up for about 75 minutes. The voltage will drop to about 7.55 volts. I stop flying when the pack voltage drops there eventhough the nominal voltage for a lipo is 7.4V.
There are several other advantages to the TA IBEC but you can read about them on Ed's site so I won't bore you. A Y to the battery pack, with all due respect, does not compare...
As far as the 40$ price, heck man, what price do you put on a 2500$ airplane which depends on this gizmo doing its thing?
My Feedback: (198)
If using a Y, and *wanting* to have remote ignition kill, you pretty much have to use an electronic switch controlled by a receiver channel actuated from the Tx.
I think most who have responded here already would wholeheartedly agree that an accepted "best practice" is to have the TX operated kill.
As others have said - there are lots of ways to set these up that work very well. I just thought I should mention the switch configuration because in my opinion, that is as important as the to Y or not to Y consideration.
Bob, you make a point worth reinforcing. Put me on the list of guys that wont fly a gasser without a transmitter controlled switch. Not only are they a huge asset when it comes to safety (consider a gasser in the pits with the receiver switch left on - and somebody walking up to it to check out your prop), when you get used to having one, it's like power windows in your car. They're convenient....
Why can't people discuss options without the conversation being called an argument?
My Feedback: (19)
AZ
I suspected you might have personal interest in the device.It belongs in the 72 era.
If it has a regulator it is a power waster. Thats how they perform their function. They throw away part of the power.
I have used an IBEC in a pair of 20cc powered warbirds for about 8 years now with no issues at all. They work. That being said, given the roughly 2 ounce weight of an 1,100 mah LIFE battery, dual batteries is viable and cheaper. If you want to use a 700 battery, which weighs about an ounce, weight is even more insignificant.
I hope everybody pays attention to ahicks observation. Opinions are the reason for these forums and should not be an opportunity for argument and personal attacks. If you are so inclined, there are more serious issues involved. Find another outlet.
My Feedback: (31)
Simple answer, yes. FWIW I started using Tech Aero ibec's when they first became available and have used them along with A123 bats. since they came on line in every gasser I have owned which at my age are now too numerous to count or it could be CRS. Never a failure and I believe much safer. YMMV.
My Feedback: (198)
Well, Oil doesn't need further discussion, once everyone learns about Pennzoil Air Cooled @ 30:1. Of course, there's always an errant AMSOIL user here or there...."the Un Enlightened"...
