Smoke muffler connections?
My Feedback: (14)
What kind of tubing and fittings are you guy's running for the smoke systems on gas engines?
I'm having a hard time with the tubing melting right off the smoke tap on the J&A muffler on my BME 50cc.
Is there a special high heat tubing you use from the pump to the muffler?
Thanks for any info or tips.
My Feedback: (9)
WA
RE: Smoke muffler connections?
What are you using now? The only stuff I'm aware of that can take the heat, AND is resistant to smoke fluid and gasoline, is the neoprene fuel tubing. Many of the suppliers sell it as fuel line but also specifically sell it for smoke taps.
Sam
Sam
