Scott Ellingson
TX
Scott Ellingson
This guy is phenominal! If you need a gasser, get one from him. I just got his 25 CC GT Torro conversion, and it's turning a MAS 16 X 8 at 8250 on the ground, and it's not even broken in yet! Pretty strong for that sized motor, IMO.
Also, what makes it so great is his service. The man will go way beyond the call of duty to help you with any and all problems you might have. If you want service, go to [link=http://www.scottellingson.com]www.scottellingson.com[/link] and check out his engines.
My Feedback: (14)
RE: Scott Ellingson
2Slow2Matter
I totally agree with you on this. Scott is the best guy I have every met when it come to backing up his product and give his customers a quality propduct. Try using a APC 17x6 prop on this engine I think you'll like it a little better. I am getting 8800RPM with this prop one the ground and it is putting out 14+ lbs of thrust. Here is a like to the video so you can see for yourself.
http://media.putfile.com/Brillelli-2...ngine-Test-Run
http://media.putfile.com/Giant-Big-S...25cc-GT-Engine
