DLE30!
#4301
MI
RE: NEW DLE30!
ORIGINAL: captinjohn
What are the specs on the 2 diodes you would use. Maybe I would try that myslf sometime. Thanks Capt,n
ORIGINAL: JNorton
Or two diodes in series.
John
John
#4302
My Feedback: (14)
AL
RE: NEW DLE30!
My new DLE 30 Electronic Ignition has three wires other than the spark plug wire. The middle wire that is black/red/white has a tag on it stating rpm plug... I am confused on were that connects... ..The red plug, with red/black wiring is the power I believe so what do I do with that middle wire/connection? thanks...
#4303
RE: NEW DLE30!
ORIGINAL: Richard39
http://www.aero-works.net/store/detail.aspx?ID=447
#4304
My Feedback: (14)
AL
RE: NEW DLE30!
Thanks William... I take it that your reply is to say that the wire in the middle that states RPM goes to a tach and serves no other purpose... I had considered that it went to the receiver.... but seems not..... can I just let that connection just be unplugged as I have not heard anyone talking about a tach connector on their gas engines....
thanks... Richard
thanks... Richard
#4305
RE: NEW DLE30!
ORIGINAL: Richard39
thanks... Richard
thanks... Richard
Sheldon
#4306
NY
RE: NEW DLE30!
ORIGINAL: Richard39
I still like a hand-held tach because once it's tuned and running well I don't need a constant check on the tach. I guess it could be nice to use one of those plastic Ernst plug port fittings to plug the tach into...
#4307
SD
RE: NEW DLE30!
ORIGINAL: cmoulder
[link=http://www.syssaaircraft.net/cart/pc/viewPrd.asp?idcategory=2&idproduct=19]Digital tach[/link] that works off the CDI.
ORIGINAL: Richard39
That is one great idea, use a Ernst plug to plug the Tach into. I will try that on my new project.
Thanks - John k
#4310
RE: NEW DLE30!
I've read that the DLE30's carb isnt the best walbro clone, would i be better of using a Walbro WT-793 (from a CRRC 26cc) or is this a pointless move?
#4313
RE: NEW DLE30!
ORIGINAL: Richard39
Great Photos Capt. clear as a bell.... I did not see the spring in the spark plug cap.... just not in the picture.... do you use that spring? is it required? thanks...
#4314
My Feedback: (19)
RE: NEW DLE30!
ORIGINAL: martseger63
#4315
My Feedback: (19)
RE: NEW DLE30!
ORIGINAL: Richard39
#4317
RE: NEW DLE30!
The springs function has been explained here many times. It is to enhance the ground capability of the plug cap, it also helps prevent RFI in the event the caps fit becomes less than ideal from wear. It's true the engine doesn't need it to run but I use them for the previously stated reasons, when they're installed correctly they do not hinder the installation or removal of the plug cap.
#4319
NY
RE: NEW DLE30!
Well stated, Jody.
I discovered a loose cap during the past flying season. I will never know if the spring actually averted the loss of an airplane, but a deadstick at a very bad time can easily end up that way.
In any event, it didn't hurt. One more contact area is never a bad thing.
#4320
My Feedback: (19)
RE: NEW DLE30!
ORIGINAL: jedijody
#4321
RE: NEW DLE30!
The springs are supplied by Rcexl with the DLE ignition, Rcexl sells them separately. Besides the DLE ignition the only ignition that Rcexl includes them in is the one for 1/4-32 spark plugs. The spring goes into the cap large end first, to install the spring into the cap, squeeze the spring flat between your thumb and finger, push the spring into the cap on its edge until it slips into the cap then rotate it down into the cap, use a small screw driver to straighten out and organize the coils.
No one says you must use the spring, useit or not, it's your call, I do. I'm not going to try to talk anyone into it's use or prove anything about it, it's a pretty simple concept to understand and extremely easy to use, that's enough for me.
#4323
RE: NEW DLE30!
What do you think guys...since the DLE30 is not going to be "new" in 2011...should we then start a thread called ...2011 news about the DLE 30. It is simple to do and maybe start with the main specs....Just a Idea ....Capt,n
#4324
NY
RE: NEW DLE30!
What do you think guys...since the DLE30 is not going to be ''new'' in 2011...should we then start a thread called ...2011 news about the DLE 30. It is simple to do and maybe start with the main specs....Just a Idea ....Capt,n
I've thought for some time that the word "NEW" should be banned from thread titles because stuff is only new for a relatively short while. It's funny to stumble across a thread that is 6 or 7 years old with the NEW still in the title!!
