31% Colombo Anderson Extra 300L
#54
OH
RE: 31% Colombo Anderson Extra 300L
Some drawings of the color scheme I am thinking of using. Planning on using Yellow, white, metallic plum and true red as my colors. Tell me what you think, I'm open to suggestions or even better submit your own drawings to help me out. I like the left wing panel on the first drawing the best so far.
Mark
Mark
#57
OH
I'm thinking around 19 lbs is where I am going to end up. If I end up at 19 the 60 should be great on it, any heavier and I may be wishing I had the 80.
Mark
Mark
#58
Im going to test fly my 31% sat. and i was just wondering if theres anything i need to look out for on the first flight.
#60
My Feedback: (21)
Steven
#61
I have'nt put it on the scale yet but from just picking it up it dose'nt feel to bad.As for power it has a 3W75 on it as for servos I have 5925's all the way around.The only thing I wished I could have for the plane was carbon fiber gear for it.I could'nt find anyone that made them for it.[&o]
#62
OH
Get us some pics of it if you have any, and don't forget to give us a full flight report after you fly it. Can't wait to get mine ready to fly. Have you tried Graphtech rc too see if they will make you a new gear? I would have them make it a little taller if you have them make one.
Mark
Mark
#65
hey mark
we will have to go flying, I ordered servo's for a new plane(40%) and maybe the engine next week. but lets get out to fly with brett and your brother. that plane looks really nice. I like the tail and can box. I have over 100 flights on my plane now and you'll have that many soon. see ya dewey
#70
My Feedback: (99)
TX
Well thats good im having trouble getting mine to idel low enough to stop pulling the plane on the ground. wish i had the walbro on mine, there's a reason they did the swap on that and i wish i knew why. when i do get it to idel low enough it shack's bad
#71
regarding 1st question on this thread ,
Spinner size:
I talked to Marcelo Colombo yesterday.. he said the right size of the spinner would be a 3 3/4 inches, but he recommended me a 3 1/2 which will look nicer.
I am not sure we were talking about the same plane!!!
So Think I will go for a 4inches spinner.
Propeller
I am gonna use 24x10 Menz standar to make break in, then 26x8 Carbon Menz or Meijliz
Weight
should go 18-20 pounds
Engine
I chose 3W 75i
regarding counterbalances.. As soon as I get the plane flying I let you know..
all the best
Juan
Spinner size:
Propeller
Weight
Engine
I chose 3W 75i
all the best
Juan
#72
OH
RE: Spinner Size
3 1/2" spinner will definetly look to small, I have one on hand and it's not nearly big enough. I think a 4 1/4" spinner would look good but no one I have found makes one so I will probably go with a 4" spinner.
Mark
Mark
#73
OH
Well I ended up having to shorten the engine box, I have an older set of instructions that state the distance from F2 to the front of the engine to be 290 mm but the newer instructions on the web site show 270mm for the 31% and 290mm for the 34%. I ended up at 278mm to clear the cowl, cut 12mm off of the side rails. The engine still ended up centered vertically on the firewall.
Mark
Mark
