Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
Reload this Page >
31% Colombo Anderson Extra 300L
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 09-06-2003, 01:56 PM
  #51
Steve
My Feedback: (54)
Steve's Avatar
Default 31% Colombo Anderson Extra 300L
Could you take a photo standing next to the plane with the nose on the ground and the tail in the air so I can get an idea of fuse area and size?
Steve
Old 09-08-2003, 08:25 AM
  #52
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
Default RE: 31% Colombo Anderson Extra 300L
WOW..... he did What happened to the picture
Old 09-08-2003, 03:19 PM
  #53
Mark_O74
I don't think any of the post from Saturday on are included, I believe I saw a message that said they would be added later.
Mark
Old 09-10-2003, 06:26 AM
  #54
Mark_O74
Some drawings of the color scheme I am thinking of using. Planning on using Yellow, white, metallic plum and true red as my colors. Tell me what you think, I'm open to suggestions or even better submit your own drawings to help me out. I like the left wing panel on the first drawing the best so far.
Mark
Old 09-10-2003, 07:25 AM
  #55
mups53
My Feedback: (41)
Nice scheme. I like the yellow because it shows well in the air in almost every sky. Mike
Old 09-10-2003, 08:50 AM
  #56
Shortman
My Feedback: (21)
Shortman's Avatar
How much do you think this 31% will weigh in at Mark? I am hoping its feasable to get it under 20lbs without much work.
Steven
Old 09-10-2003, 06:29 PM
  #57
Mark_O74
I'm thinking around 19 lbs is where I am going to end up. If I end up at 19 the 60 should be great on it, any heavier and I may be wishing I had the 80.
Mark
Old 09-11-2003, 10:03 PM
  #58
ici
Im going to test fly my 31% sat. and i was just wondering if theres anything i need to look out for on the first flight.
Old 09-11-2003, 10:59 PM
  #59
furloughed ual
My Feedback: (31)
furloughed ual's Avatar
ici......What's the weight and with what motor?
Old 09-11-2003, 11:17 PM
  #60
Shortman
My Feedback: (21)
Shortman's Avatar
Could we get some pictures from ya? I am really anxious to hear how the 31% flies compared to its older brothers...
Steven
Old 09-12-2003, 12:13 AM
  #61
ici
I have'nt put it on the scale yet but from just picking it up it dose'nt feel to bad.As for power it has a 3W75 on it as for servos I have 5925's all the way around.The only thing I wished I could have for the plane was carbon fiber gear for it.I could'nt find anyone that made them for it.[&o]
Old 09-12-2003, 06:43 AM
  #62
Mark_O74
Get us some pics of it if you have any, and don't forget to give us a full flight report after you fly it. Can't wait to get mine ready to fly. Have you tried Graphtech rc too see if they will make you a new gear? I would have them make it a little taller if you have them make one.
Mark
Old 09-12-2003, 06:51 PM
  #63
deweyd
ICI
check with planes plus , I think don should have a set, but if not graphtech should have a set..
Old 09-12-2003, 07:05 PM
  #64
Mark_O74
Hey dewey
Hoping to have mine ready around the first of October. Well have to get together sometime once its done.
Mark
Old 09-13-2003, 10:13 AM
  #65
deweyd
hey mark
we will have to go flying, I ordered servo's for a new plane(40%) and maybe the engine next week. but lets get out to fly with brett and your brother. that plane looks really nice. I like the tail and can box. I have over 100 flights on my plane now and you'll have that many soon. see ya dewey
Old 09-13-2003, 05:59 PM
  #66
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
Hey mark_074
Have you run your zdz 60 yet, or is it still new?
dennis
Old 09-13-2003, 07:54 PM
  #67
Mark_O74
Dennis it is still new, haven't run it yet.
Mark
Old 09-13-2003, 08:23 PM
  #68
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
mark what carb do you have on the motor? bing or walbro.
right now i have a zdz 60 that has a bing on it.[:@]
Old 09-13-2003, 11:52 PM
  #69
Mark_O74
It's a newer one with a Walbro carb. I worked on the engine box tonight, hopefully will have time tomorrow to finish it up.
Mark
Old 09-14-2003, 08:04 AM
  #70
DENNIS C
My Feedback: (99)
DENNIS C's Avatar
Well thats good im having trouble getting mine to idel low enough to stop pulling the plane on the ground. wish i had the walbro on mine, there's a reason they did the swap on that and i wish i knew why. when i do get it to idel low enough it shack's bad
Old 09-15-2003, 05:57 PM
  #71
jegi75
regarding 1st question on this thread ,
Spinner size:
I talked to Marcelo Colombo yesterday.. he said the right size of the spinner would be a 3 3/4 inches, but he recommended me a 3 1/2 which will look nicer.
I am not sure we were talking about the same plane!!!
So Think I will go for a 4inches spinner.
Propeller
I am gonna use 24x10 Menz standar to make break in, then 26x8 Carbon Menz or Meijliz
Weight
should go 18-20 pounds
Engine
I chose 3W 75i
regarding counterbalances.. As soon as I get the plane flying I let you know..
all the best
Juan
Old 09-15-2003, 06:38 PM
  #72
Mark_O74
Default RE: Spinner Size
3 1/2" spinner will definetly look to small, I have one on hand and it's not nearly big enough. I think a 4 1/4" spinner would look good but no one I have found makes one so I will probably go with a 4" spinner.
Mark
Old 09-16-2003, 06:51 AM
  #73
Mark_O74
Well I ended up having to shorten the engine box, I have an older set of instructions that state the distance from F2 to the front of the engine to be 290 mm but the newer instructions on the web site show 270mm for the 31% and 290mm for the 34%. I ended up at 278mm to clear the cowl, cut 12mm off of the side rails. The engine still ended up centered vertically on the firewall.
Mark
Old 09-16-2003, 08:48 AM
  #74
Shortman
My Feedback: (21)
Shortman's Avatar
Does anyone know the correct C of G or the throws???
The manual that I have online doesn't tell you much lol
Steven
Old 09-16-2003, 06:07 PM
  #75
Mark_O74
They say to start at the wing tube for the CG. Throws, haven't seen them listed anywhere.
Mark
