Velox Revolution II (81")
John:
The t-nut for one of the wing retainer screws (the 90MM) is stripped out in my kit. Since this t-nut is buried deep in the wing, it would require major surgery to replace it. I was thinking of installing 8-32" brass inserts in all the wing bolt holes and swapping out the 4mm metric hardware. Do you see any problems in doing this?
Tony M.
Tony M.
FL
RE: Velox Revolution II (81")
Hello,
No problem or you can tap the wood root cap and use a nylon screw. They wont come out either and it may be eaiser. Let me know if I can help further.
John
John
Would the Zeonah G45 (heavy but reliable) be a good match for the 50cc Velox II?
I am concerned about having to add dead weight in the tail like I did with my Christain Eagle II.
Thanks!
Thanks!
FL
Hello,
It should. With a DA50 RTF most planes are comming out at 15.5-16lbs. Im sure that 220 Saito would do well but we have no experience with it.
John
John
My Feedback: (24)
PA
john - thanks for the reply - my thoughs are this - with the saito 220 it will be about 20 t0 24 OZ. lighter then 50 size gas - so this will have a lighter wing load , have a nice scale sound , and less viberation on the air frame - 3-D is not thing - i like a nice classey looking airplane with that a softer sound - thanks again Bill wrc-flyer ( i have the arf seting by the bench )
My Feedback: (7)
dhooks, im flying mine and i woouldnt trade it for anything. almost flyies as well as my 40%. its nothing for me to do a 6" inverted pass over the runway, or for that matter any manuever in the book (well that i can do!!). flys great very stable very perdictable, "0" bad habits
