Servo Arms for 25% 3D Plane
I'm building a 25% (50cc) size 3D aerobatic plane and I'm looking for long aluminum servo arms for the Hitec servos I'm putting in. All I can find are the dubro heavy duty servo arms. I bought them and they're fine to test the plane and stuff, but they definitely are not long enough to give me 3D throws. I got a pull pull system for the rudder, but even on the narrowest possible setting on the rudder side, I won't get more than about 30 degrees throw.
Can anybody tell me where I can buy long aluminum servo arms for Hitec servos (online)?
Thank you!
Thank you!
My Feedback: (15)
AE, GERMANY
RE: Servo Arms for 25% 3D Plane
Go for the Airwild, MPI, or SWB arms. These will give you all the throw you need. Remember the longer the servo arm the more reduced the servo power. Here is one source to get your arms:
http://www.troybuiltmodels.com/newsi...servoarms.html
There is a lot you should do different when building a bigger plane; if you have questions please ask! Too much knowledge out there to be unsure on a first larger setup.
If you're setting up right you shouldn't require anything longer than 1-1/8". More than that and you're doing something wrong at one end or the other. The arms that come with Hitec digital servos would work nicely for you. Perhaps you might try contacting Hitec and attempt to obtain some, or talk a friend out of any they might not be using.
ORIGINAL: airborneSGT
ORIGINAL: Tired Old Man
Thanks for the tip, as I was gonna buy new horns for each surface, but that's not necessary (other than the rudder).
