*Cirrus SR22T 30cc ARF by Hangar 9*
My Feedback: (10)
RE: *Cirrus SR22T 30cc ARF by Hangar 9*
Looks like the cylinder head will stick out of the cowl just a little. The distance from the engine box to the backplate looks like it might work out without any mods for the DLE 35RA. The distance for the engine is 6 3/8" and it looks like that will leave a 1/8" gap between the cowl and the back plate. That's a little more than I like but should be fine.
Looking good, thanks for the photo,s & up dates.
How does the nose gear & attatchment point look ?
Supposedly the week point on a smaller Great Planes version of this aircraft.
I,ve just had an update from the importer here in Australia, the Cirrus is due in on 15th June, their taking backorders at $699 Aus, inc free shipping , our dollar is almost exactly equal to the US dollar, how does this compare to what you guys are paying ? Not that it makes much difference i cant possibly get one from the states with the shipping, but just nice to know.
Winter has arrived in Aus I,m South in Victoria, max about 15 deg at the moment, fair bit of rain, & wind, after a great summer,not much flying lately.
My Feedback: (10)
ORIGINAL: BANK N YANK
Winter has arrived in Aus I,m South in Victoria, max about 15 deg at the moment, fair bit of rain, & wind, after a great summer, not much flying lately.
#32
My Feedback: (10)
Well, unfortunately I have to send my fuse back to Horizon. I noticed at the top when I drilled my holes for my stand-offs that there was a gap. There is about a 1/2" gap between the fiber glass and the inner plywood firewall. Didn't really think about it when I was mounting my engine for fit. I guess I was in to much of a hurry to see what it looked like. You can see in the pic that the top of the firewall is leaning backwards.
#33
Thats very disapointing, Hanger 9 quality has always been so good, i,m sure they will want to rectify the problem for you. & not want the bad publicity on here, getting too far.
Or you could just mix up some epoxy & syringe it into the cavity through the engine mount holes. You would need to be sure the whole space was filled, to be sure when mounting the motor the cavity would,nt be crushed.
Good luck which ever way you go, let us know.
#34
Oh yea, & are the 4 mounting holes in the bottom of the fuselage front for mounting the nose leg ? how good do you think that set up is, strength wise, sure to cop a pounding on the occasional heavier landing, or a lot of the time on the grass strip at my club.
Thanks Zippi
Thanks Zippi
#36
My Feedback: (10)
BANK N YANK,
I guess a fellow could fill the void with epoxy or cut the fiber glass away and add washers but I have taken the fuse back to my LHS for a replacement. Should be in by Tuesday. For this kind of money I want it right. The 4 holes below the engine box are the mounting holes for the nose wheel. I did take a look at it and there is no way to get to it from the inside as it's covered up by the tray. I think the only thing I can do is stand the fuse on it's nose and drop some epoxy in and let it conform to the block that is there. Other than that I'll just have to make sure I grease all the landings.
#39
My Feedback: (16)
ORIGINAL: Zippi
Looks like the cylinder head will stick out of the cowl just a little. The distance from the engine box to the backplate looks like it might work out without any mods for the DLE 35RA. The distance for the engine is 6 3/8'' and it looks like that will leave a 1/8'' gap between the cowl and the back plate. That's a little more than I like but should be fine.
I should be getting this plane next week. Do you think a Saito FG57 twin would fit in the cowl without it sticking out? Look forward to all your views.
My Feedback: (10)
ORIGINAL: veroaviaor
Hi guys,
ORIGINAL: Zippi
My Feedback: (10)
Well, I went to my LHS today to pick up my replacement fuse and as luck would have it the rear of the fuse was cracked with paint popping off. Looked like someone had stepped on the plane and went ahead and put it in the box. The outer box was not damaged. I was also tapping my finger on the fiber glass engine box and this one sounded hollow at the top where the holes needed to be drilled for the stand-offs. It may have the same issue as my first one. Illinois does not have another fuse so the LHS had to order one from California. If this one comes in damaged I'm sending everything back for a refund. Horizon Hobby at this moment is really starting to leave a bad taste in my mouth. Where is the quality control???
#42
Very disapointing, i,m tipping Horizon will be cheesed at the quality problems too, my last 2 of there models were so good [ P47 Thunderbolt Razerback fitted with OS BGX 35cc & Taylorcraft with the V twin Laser 33cc, that i have duplicates sitting on the shelf in the garage waiting for the enevitable, had literally hundreds of flights out of them both ] after all,there all only on loan. There quality, ease of build & longevity are why i was so interested in the Cirrus, maybe i need to hold off now for a bit ??
Best of luck Zippi, but they must want to put it right, maybe you should mention the press there getting on this forum, if the next step doesnt work out, but i would give them one more shot ??
#43
My Feedback: (10)
Very disapointing, i,m tipping Horizon will be cheesed at the quality problems too, my last 2 of there models were so good [ P47 Thunderbolt Razerback fitted with OS BGX 35cc & Taylorcraft with the V twin Laser 33cc, that i have duplicates sitting on the shelf in the garage waiting for the enevitable, had literally hundreds of flights out of them both ] after all, there all only on loan. There quality, ease of build & longevity are why i was so interested in the Cirrus, maybe i need to hold off now for a bit ??
#46
Too simple, like me i guess, there doing it tough here, even the importer [ long time wholesaler is now selling on-line, ] the LHS,s here are not long for this world i fear.
#47
My Feedback: (10)
I'm banking on the 3rd fuse to be trouble free so while I'm waiting for the fuse to arrive hopefully next week sometime I decided to do a little more work on the rest of the plane. The weld on the axles is a little to sloppy so when the plastic spacers is put on it sets the wheels to close to the cutout in the wheel pants. I had to shave about 3/16" off the wheel pants to get the clearance for the wheels to spin freely. On the left wing only the gap between the ailerons and flaps was way to close so I had to cut off enough so the flap would operate to it's full range.
#48
Hanger 9 quality seems to have gone down the toilet lately. How hard can it be ? to get it right, If I ran my business like that I would soon run out of customers.
I was reading the thread on there 88inch Tiger Moth, & that too has issues that the end user should not have to deal with. C.O.G. printed incorrectly in the manual, incidence wrong on the stab, these 2 alone could cause a less experienced modeler to loose there aircraft on the first flight. plus several other ill fitting parts, not good enough, Hanger 9.
#49
My Feedback: (10)
BANK N YANK,
I agree with ya dude. Everyone please keep in mind that most of the issues I've found so far are not a Hugh issue. But, they are things that I feel should have been caught before the release of the plane. The main issue was the firewall which in my book was a major issue. The Cirrus SR22T is still a very nice looking scale plane and once it's finished should be a nice addition to my hangar.
#50
My Feedback: (10)
My LHS received my 3rd fuse today so I went over to pick it up after work. As the hobby shop owner and myself opened the box the first thing we noticed was that there was no packing. It was wrapped in one plastic bag with one loose box inside. This was a very poor way for this to be shipped from California. The fuse was cracked in multiple places and the paint was very poor. The tented glass on the doors looked like someone had dragged them across a floor as they were full of scratches. Very unacceptable. The hobby shop owner still had the other two fuses that I had returned so we tried to swap out the doors only to find out they would not fit and the paint lines were way off. My LHS called Horizon while I was there and explained the issue. Illinois and California are out of the fuselage so they are sending a whole new ARF. My LHS owner and myself agree that if this one comes in just as bad as the others then that's it. It's all being shipped back for a full refund. I think I have been more than patient. This will be the lasts H9 product that I buy no matter how the next fuse is when it comes in.
