TMMY Scale Composites 35% scale Cessna
#1451
My Feedback: (206)
RE: TMMY Scale Composites 35% scale Cessna
ORIGINAL: frets24
Tshark,
That pic of you and the ''mini-me'' pilot figure is awesome!! I'm sure that will be the hit of the field once somebody susses out that the figure is YOU I've spent 100's of hours in a 172 Cessna and your I panel and interior look great!
Tshark,
Well I spent half the day trying to find items here at the house, and at CVS to make my antennas out of. I think I am now on the right path. They will be close not 100% dead on but close enough by the time I get done with them. My graphics from Highr Graphics down in FL should arrive Monday Tuesday this week I will be able to get them finished up this week. Now I need to make the other 4 or so.
#1452
My Feedback: (206)
Well the first on is done more or less still waiting on the graphics for it. Not to bad for government work. Not perfect but good enough for under the plane. Got my patches scaned in and reduced down on heavy card stock. Now I just need to cut them out and put them on the uniforms.
#1453
My Feedback: (13)
NY
ORIGINAL: spidernad
Oh No!
I've discoverd RC scale rock crawler trucks!
Had to find some something to do while I'm waiting for an engine for my Cessna.
Here are a couple of pics of my first build attempt.
I know, it's not a plane.
Oh No!
#1454
My Feedback: (28)
ORIGINAL: piperfan59
Nice Axial SCX10 Dingo
#1455
My Feedback: (206)
Well I got my new mufflers in for the DA 150 next it is off to the welder with them. I can't see cutting into this nice cowl when the exhaust can be emptied out of the scale location.
I got everyone patched up this evening/morning. Is it really 3am wow. I am not sure if I want to shrink the patchs a bit more or not.
#1456
NJ
Hey Tshark the pilots look great - PLEASE let me see photos of the exhust that your doing.... As you see in my photosI cut the cowl - howerver I do have the aluminum bendable pipe to fitoverthe mufflers then run out the bottom of the cowl- I had Jtec make me a compact set.of mufflers that im using. Ijust wanted a few flights before i did that extra work...... thenI have a great Fiberglass guy that can patch the holes in the cowl.. So when you get them done please post photos........i like options......
#1457
NJ
So here is the transport stand prototype all complete. As you will see in the photos the two halfs butt right up against each other so nobody is needed to hold the tail to screw it on - Now ifyour on uneven grassI made braces that clip on the center structure ( 3 removable bars in the center) they hold it level in place... I too wish to travel to the field already connected and assembled,but do not want to risk a fracture during transport. so the tail is only on for flying at the field THATSIT..........
#1458
ORIGINAL: mifsudm
hi Tshark,
i installed the fuel system from the wing and it turned out to be awesome. i will post some pics later.
regards
Martin.
hi Tshark,
regards
Martin.
i posted some images of my wing fuel filler system, friends at the flying field really liked it.
[img][/img][img][/img][img][/img]
regards
Martin
#1459
My Feedback: (206)
ORIGINAL: mifsudm
ORIGINAL: mifsudm
hi Tshark,
regards
Martin.
hi Tshark,
regards
Martin.
What size festo are you using? Also who makes that fuel cap. It looks larger than the one I have.
George
regards
Martin
#1460
Hi TSHARK,
attached please find the web link http://www.flugmodellbau-shop.eu/ of the filler cap shop, the out side diameter is 32mm. as for the
festo i am using 6mm dia until the fuselage then i made a 90 deg angel brass pipe and continued with tygon tubing till the fuel tank.
regards
Martin
regards
Martin
#1461
NJ
Tshark great job on the fuel lines- I will plan that for the future- its never ending on the details we can do........ thanks to SpidernadI have the specs on the decals and had these done- i Know on the full scale Cessna logo is a dark gray- but I Idid the color logo just to have it pop more.......
#1463
Hi Guys,
i would like to now what size of a biela three blade prop for a DLE-170. any body has this setup??
regards
Martin
regards
Martin
#1465
thanks Randy,
did you cut out the F1 former to make space for the fuel tank?? the one supplied with the model is way to big to fit in the engine mount.
regards
Martin.
regards
Martin.
#1466
Hi Martin;
Best check with the 182 fellows re tank size and location. My tank location in the 185 with the 3W 212 was behind the firewall mounted vertically.
The tank supplied from Tommy was huge and could not be used.
I'm using a 50 ounce tank which gives me ample flight time and reserve.
If you are using a 150cc you may be able to use a tank that will fit within the motor mount.
I'll be using that set up on the next 185 and the 3W 170.
As mentioned, one of the 182 fellows will head you in the right direction.
Regards
Randy
Regards
Randy
#1468
NJ
Im using a 40oz tank with a DA 150cc - Mario some how fit a 50oz tank but I could not- I tried all different manufactures -I can only fit a Dubro 40oz in mine( Tommy sent me a huge tank) I gave it to my jet friends -can anyone tell me what brand and stlye they used, and if they can fit a 50oz tank in the engine mount witch one it is ???????? send photos of this 50oz tank in the engine mount I need proof thank you
#1469
My Feedback: (206)
ORIGINAL: mifsudm
thanks Randy,
Hi Tshark, can you let me know what size of fuel tank are using on your 182??
regards
martin.
thanks Randy,
regards
martin.
The new tank tommy is sending out does not fit correct. Unless you cut the fire wall. I tired the 50oz Dubro but the lines kept getting pinched. I am now using these http://www.bennettbuilt.com/shop/Tan...ctangular.html
they fit side by side with just a little mod needed. You just saddle them together like a jet set up. I am running about 64oz of fuel on the plane right now.
George
#1470
My Feedback: (206)
ORIGINAL: style fly
I could not stand the shiny top of the Cessna dash board - I went to JoAnn's Fabric and picked up some mat vinyl leather - I made this templet- cut one out - now it looks much better....
Do you still have the temple for the dash. Or could i get just get you to cut me one. I have a bunch of white over spray on mine that I cant get off. So I guess I will just cover it.
I am almost done with the plane. I had almost the entire plane repainted being I had mismatched paint on both my wings and fuse. New paint is sharp the colors are now correct. I got my pilot working along with the control yokes. So now the arms and head all function. Newer nav lights are coming in to replace the ones I just got from Details 4 Scale. Dan has newer and brighter strobes and beacon. They are visable from a 1/4 mile away. So she will be ready for Joe Nall here in a few weeks. Just need to finish up the rest of antennas.
#1471
NJ
Hey Tshark - I thinkI have the templet- im at work till about 5:00pm today - whenI get home Ill dig it out and send it to you -I also have the dash material -Ill shoot you a Email tonight for your mailing adress........
#1472
NJ
Hey Tshark- here is my e-mail "[email protected]" send me your mailing address - ill ship out the templet and fabric to you
#1473
hi Guys,
can anyone who owns the 182 and flown it tell me what is the approximate dry weight of the aircraft when it is ready for flight.
regards
Martin.
regards
Martin.
