Glow head brotherhood.
#1451
I only had problems with one engine concerning mufflers vibrating loose. I cleaned the surfaces with fuel, then alcohol and swabbed epoxy into the muffler threads and tightened the screws. I've also used epoxy for blind nuts and backplates on a Saito FA-82 that was vibrating loose after only minutes of run time. It just works, but I agree with Dave (Hobbsy) about virgin teflon tape. I always have a roll in my toolbox when flying.
#1452
if an exhaust flange is scratched on your engine but not too badly you can use a fine honing stone to clean it up, I have a fine, flat stone that is some 4 inches square, and it worked slick, just make sure you move the stone slow over the flange so it stays in contact evenly on the flange, for safety plug the exhaust port with a rag or that fray-less blue paper towel and wet it with WD or oil, plug it really good, and use oil to lube the stone, not spit LOL
and to help keep exhaust screws tighter, do what we do on Helis, fly around and get the engine hot, land and run over and tighten the screws (it may help, it may not), some Heli guys use gasket sealant on the screw threads, but I have not needed to try that yet
Jim
Jim
