4 stroke exhaust header
Old 07-19-2004, 03:34 PM
old propnut
Default 4 stroke exhaust header
I am installing a 120 Magnum four stroke inverted in a scale Cub and I need to turn the header 90 Deg. at the head and point the muffler down and back out the bottom of the cowling there is not very much room and a short turn is needed. I have not found anything like this offered by any one. Has any one else solved this problem or found such a header for sale.
Any help would be appreciated.
Old 07-19-2004, 04:00 PM
Xup
Xup's Avatar
Default RE: 4 stroke exhaust header
Think this is what you are looking for.(In the UK)
http://www.justengines.unseen.org/FS_mans.htm
Xup
Old 07-19-2004, 04:13 PM
rctrax
I took the elbow that comes with the engine and cut it in two and purchased a 3/8 copper 90 degree el and silver soldered the two pieces of manifold into each end, screwed them together and had a 90 degree manifold. this was for a 91 so you might need to adjust the sizes to suit.This was for an inverted installion with exhaust coming out the bottom of the cowle the same as you are doing I think.
Old 07-19-2004, 06:56 PM
Doug D.
Go to www.pspec.com They have about the same headers as Xup shows on the web page he mentions. Look under 4stroke mufflers. Seen them at Toledo this year, very good product.
Old 07-20-2004, 03:40 PM
old propnut
Thanks fellows I found what I needed at PSPEC and it is 10.00 less than Just Engines.
Fred
