ASP/MAGNUM FS400AR Rebuild/Overhaul
#1776
RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
The new RCEXL ignition for 3 cylinders radial ( 13XX series) dedicated to SAITO's are now and the market, ans LiPo 2S compatible.
However, it will take a time before to get ignitions for 5 cylinders Radial as ASP F400, but RCEXL Team is hard working on this way !
#1777
ORIGINAL: Carosel43
No you are wrong, because the pistons move up and down opposite to eachother (in effect) there is no pressure in the crankcase. Also the idea of blowby is not exactly correct, yes there is oil forced past the ringson the power strokebut its not like a jet of pressure as the term 'blow by' implies.And anyway, those instructions i put up are from the current OS300 which for sure only has the one nipple, the new OS 420 also has only 1 nipple and it clearly states that it must be blocked off while running. The 320 flat 4 is different for sure as it has the 2 nipples, the radials however should be plugged
Also in the past i have (in error) forgotten to remove the drain plug i fit to my Laser 300v (to prevent it making a mess when i hang the model up) and have flown a whole day of flying with the engine without any drama. In the 300v the movement of the pistons puts the crankcase under pressure so blocking the drain plug would cause a pressure buildup in the case. But as i said the engine didnt complain at all and there were no leaks or anything.
Consider a four cylinder car petrol engine where the pistons go up & down in pairs - in your reckoning, like the radial there would be no crankcase pressure, yet if you block off the crankcase breather, you run the risk of blowing the crankshaft seal and ruining your clutch.
And lastly, quoting from the current ASP400 manual in the lubrication section:
During the running of the engine, as well as while the engine is sitting properly mounted with the drain nipple pointed down, the excess oil will leave through the drain nipple. To protect your airplane, connect silicontubing to the drain nipple and have itrelease the oil outside of your aircraft.
I don't mean to bang on about this, but keeping the engine operating reliably seem to be hard enough for most of us so its important we all try to operate it the right way. :-)
Hope this helps.
#1779
ORIGINAL: Eulboyington
C&H has a far better sytem as far as set-up of the magnets/hall sensor. I've been doing CDI conversions on Saitos for over 15 years & putting the magnets in the prop drive washer is a poor design. Especially when one wants to run methanol fuels that require @ least 6° more ignition timing advance to get maximum performance. They are working on a "modular" module board that can be cut when fabricating to relect the number of cylinders.
#1780
Page 18 of the OS420 manual clearly shows the plug installed. While i accept your comments about car engines the displacements of air involved and the type of engine that they are is quite different.
As for the latest copy of the ASP instructions i do not have a set to look at, and even if i did it is quite likely that this has been written down incorrectly by the person who wrote the manual due to the slightly contradictory info written by OS. Logically i left mine open when my engine was running as i have on all my 4 strokes, but since i read the line on the instructions saying not to i have lef *** plugged as a test. so far i have had no problems and my model is cleaner than before.
And before we can all operate the engine the right way we need to work out what that is and from what i have seen leaving the plug in place seems to be right, especialy if low oil in the crankcase is a problem. Frankly though i think the engine would be find on 7% oil at any rate. I have done experiments with another engine and have run for over an hour on 2.5% oil without issues
#1781
Dear Kmot,
You have started the thread, for which we are looking a long time ago. Thanks for this.
Although Rebuild is time taking job, but very interesting too & some time, we have no idea about how much hours are passed.
******** is also like a disease & working with engines is more than that. we think it is a kind of & .
#1782
ORIGINAL: SrTelemaster150
I'm thinking the extra $507 might be worth it. Hardly 4X as much.
Ok, so this one is 66cc and Moki is a 150 - couldn't find anything smaller to compare when I bought my ASP.
BJ
#1784
ORIGINAL: BJ64
Sorry - but Moki 150, Price per item € 2.369,00 = AU$2961.00 ~ 4 times as much.
BJ
BJ
You referenced to both Saito and Moki.
ORIGINAL: BJ64
Sure, it's no Saito or Moki - and doesn't come in at 4 times that asking price either...
BJ
BJ
I made no mention of Moki in the text I posted.
I was seriously considerinmg the ASP hoping that QC had inproved over the early versions.
After all of these posts about problems W/the current batch, I'll save up another $500 & buy an engine that I can depend on. It would be foolish to risk a $1500 airframe on an unreliable engine.
#1785
My Feedback: (24)
Yes, we all know that Saito and OS engines are much higher quality than Sanye. What's new?
But this thread is basically about the Sanye (ASP, Magnum, SC, PH) FS400 radial engine and it's care and feeding.
It is a celebration of this engine and it's quirks, idiosyncrasies, faults, and as well its joys.
If you only wish to denigrate this engine, and by association its users, perhaps it's time to move on.........
#1787
ORIGINAL: Kmot
#1789
CA
I was working with my 400 today trying to figure out how I will mount this motor on the CMP Zero. I have to say that the engine is a work of mechanical art. I just can't help but love it. Mine looks great and I checked the bolts, all were tight. Maybe I will get lucky and get a good one.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
#1790
Did you actually read my entire post?...
This is an ASP FS400AR thread - you do not own one, and have gone out of your way to tell us that you will never own one.
One wonders why you post in this thread at all.
From my observations so far, I see you bang on about other radials, CDI ignitions blah blah blah... and you seem to take enjoyment out of bagging the ASP 400.
Anywhere else, that sort of behaviour would be considered "trolling".
BJ
#1791
Let's just be honest and not dance around the facts. Everybody needs to change their outlooks a bit, and everyone needs to be more tolerant and friendly.
Yes, someone new did bring fresh opinions and some of them were about comparing engines. But, I'm making the judgement call that he was also trying to be helpful. Present members began to think this thread belonged to only a few, select members and they were't exactly the friendliest bunch.
This thread doesn't belong to anyone or any group. Every member should feel free ask or post. And, we should remain generally on topic.
#1792
Yes - this thread does not "belong" to anyone. Nor does any other thread.
Having said that, there are specialized threads that try to deal with a specific topic/product.
I would think an "ASP/MAGNUM FS400AR Rebuild/Overhaul" thread would fit that category.
Constructive criticism is usually welcome anywhere - but I feel that blatant product-bashing could best be served elsewhere.
Perhaps a "Don't buy an ASP 400" thread would be more fitting for that - and the ensuing bun-fight and rhetoric spared from this thread.
We had the same problem over in the JetJoe Owners thread for years - hundreds of heated posts and bagging of the product. Until we had a Mod that said 'enough is enough', and cleaned-up all the pointedly deliberate negative posts that continually tried to derail the thread.
It would be nice to know that enthusiasts of the ASP 400 have a place to share their trial and tribulations, as well as their enjoyment of this particular product.
Please respect those that have a genuine interest in the engine.
BJ
BJ
#1797
O/T - at the time, yes - the were worth the price IMHO.
If nothing else, they put the squeeze on other manufacturers to stop being so silly and asking ridiculous prices for what is in realitly pretty basic technology and helped gradually bring the prices down in general. If I were to go down that road again right now, I would probably choose a KingTech. Equiv power (31lb) in a kero-starter is currently only about 200 bucks more than what I paid for my JJ's (which are propane ignition) - but that was a few years ago now.
Back to my 400 - I'm not sure how to go about ordering the bits I need for my rebuild of the front end. I may as well get a full set of bearings while I'm at it now that it's apart - and I'm not sure how much any of them may have been lube-deprived or for how long. So I might as spend a few extra bob now and do the lot (and I'll pre-lube them too ).
While I can see a few of the more popular parts like head, piston, and piston sleeve on the HK website, I haven't been able to locate any of the other parts yet.
Any suggestions?
BJ
Any suggestions?
BJ
#1798
My Feedback: (24)
You can order all the spares from [link=http://www.justengines.co.uk/]Just Engines[/link] in the UK.
If you don't have a bearing supply in OZ, you can order from [link=http://www.bocabearings.com/]Boca Bearing[/link] , [link=http://www.rcbearings.com/]RC Bearings[/link], or [link=http://www.vxb.com/]VXB[/link] in the good 'ol USA. I have used all of these companies in the past.
Reverend alerted me to a German supplier,[link=http://stores.ebay.com/Tusneldas-Kugellager-Shop?_rdc=1]Tusneldas[/link], and I recently ordered my bearings from them. Including shipping the prices were quite good and the bearings are all quality, if not exactly German made.
#1799
Thanks Tom.
How would they know what bearings to sell me? My exploded view lists ASP 400 part numbers, and in a couple of cases what look like a bearing serial number, but Google doesn't return anything for these bearing part numbers i.e. the numbers on the bearings must be some sort of general "chinese" bearing with no SKF etc. equivalent.
Same goes for the timing gears - would Just Engines know which part/s I need by the ASP part number?
BJ
BJ
#1800
ORIGINAL: BJ64
Thanks Tom.
BJ
Thanks Tom.
BJ
