Antique RC engine
FL
Antique RC engine
Hi, I own this vintage engine and know very little about it. It does turn over, compression feels good and no scraping or grinding bearings. I have been told that it is a D&S .29 from 1939 made in Lima,Ohio by Joe Delong and Bob Steele. Bottom front rotary intake valve,sand cast engine. Does anybody have any additional information regarding this engine? Any help would be appreciated.
FL
RE: Antique RC engine
ORIGINAL: big max 1935
Looks D&S to me . Should have name stamped on rear of engine . The 1940 version had a side intake . Looks like yours if missing the timer assy or I can't see it in the pictures. Max H.
FL
FL
May have had a replacement crankcase at one time. Max H
FL
ORIGINAL: daytonarc
Fyi this engine is available for a fair price, if any interest PM me.
My Feedback: (9)
Should be a set of points & some kind of a cam on the crank or thrust washer that opens & closes the points when the prop is turned over . Also a arm on the timer to advance & retard the timing.Looks like you are missing some parts. Kind of a rare engine but condition is everything & will reallly drop the collector value due to any missing or broken parts . Good luck, Max H.
FL
Thanks Max. I think I may just keep it as a cool wall art thing. Compression is good and baerings feel smooth, who knows, maybe some day I will figure out how to fire it up.
