Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
81inch antic
Old 02-26-2003, 10:41 PM
buck1856
My Feedback: (49)
buck1856's Avatar
Default 81inch antic
I am basically new to rc.only been in for a little over 6 months.could anyone tell me how the lou proctor antics fly.a guy just gave me one that needs a little work to make it flyable.just want to know if its worth the while.its built,has the original floats,plans, ect...plans say drawn in 65,revised in 72.honest remarks would be appreciated even if there bad. thanks
Old 02-27-2003, 05:44 AM
Vulturetec
Vulturetec's Avatar
They fly great, like a trainer - but learning to fly coordinated rudder/aileron will help. I think Proctor will sell individual parts if you need them to get it flying.
Old 02-27-2003, 08:11 AM
BMatthews
BMatthews's Avatar
Only ever saw one fly but it was SOOOooooo pretty in the air.
Not much in the aerobatic department. Simple chandelles, the odd floppy loop and that's about it. Don't even think about inverted.
But on a windless day you can fly it around at grasstop height and have a ball hedgehopping over dandilions.
If you put anything other than a mild 4 stroke into that model I may have to come over there and hurt you... It's a model that more than any other demands that 4 stroke sound to go with the design. 2 Stroke it if you must at first but ask for a 4 stroke for your next birthday. They don't need much power at all. The one I saw flying did fine in the air on about 1/2 throttle from it's 40 2 stroke. This was a LONG time ago when 4 strokes weren't as common. And it didn't sound right even then.
If you're low in stick time I'd get someone to help you for the first few flights. It's very trainer like in it's flying but as I'm sure you can see from looking at it it's a bit fragile. It won't take kindly to the normal beginner mishaps during takeoffs and landings.
One good thing about it. With all that drag it doesn't build up speed in a dive very much. That's a good thing for a trainer.
I
Old 02-28-2003, 09:45 PM
JDHammer
JDHammer's Avatar
Hello Buck,
Consider yourself very lucky to be given a Proctor Antic-what a sweet airplane! It has no bad habits and is pure, relaxing fun. My Antic is starting its 23rd year and the only maintenance required so far was engine valve adjusting, receiver battery replacement and replacing one drag wire. It draws a crowd because people like to watch its low and slow "antics".
Old 05-07-2003, 04:10 PM
John Cole
Yes, it`s a wonderful design. I`m on my third one, current one powered with an OS .70 4-stroke. They are a blast to fly, and I`ve trained quite a few people on them. Actually, you can rig the wings with more dihedral which will help a little with roll/ yaw coupling. I used this model to learn about rudder use and slips.
John
Old 05-09-2003, 04:11 AM
RCJake-rcu
My Feedback: (7)
Default 81 inch Antic
John Cole and I need to fly our Antics in formation sometime...he has the Monoplane and I have the Bipe. Mine has an OS 90 four stroke and the only time that I get above 1/2 throttle is when I want to do a loop or stall turn.
Keep & fly your Antic...you will never regret it.
Old 05-09-2003, 10:17 AM
Mike Denest
Mike Denest's Avatar
Hey rcjake,
That's a sharp machine What is the prop you have on it and how did you do the lozenge fabric?
Old 05-09-2003, 12:10 PM
RCJake-rcu
My Feedback: (7)
Hi Curly,
Thanks! The prop came from Proctor, I believe, and is for static display only. I did not build my Antic, but the guy that did cut templates and painted each color on the Super Coverite, then ironed it onto the wings. The bottom of the wings, fuse and tail feathers are all painted a dull, weathered red along with the Williams Bros. wheels. The wood on the front part of the fuse and some of the wings are stained.
I have a lot of fun flying the Antic Bipe and it always draws attention at the field.
Old 05-09-2003, 01:08 PM
Mike Denest
Thanks rcjake. I have the biplane kit along with the 4 stroke, upeer wing center section and float kits. One of these days, I gotta clear off the bench and build it. I've seen them with German markings like yours, British and early aeroplane. I think I might do mine as a circa 1912 aeroplane or early 1916 AEF colors. "Watch out for the Hun in the sun".
I also have the plans for one done as an Albatros DII that was published in Scale R/C Modeler a few years back. The designer borrowed heavily from the Antic bipe to do it.
Old 05-11-2003, 11:02 PM
buck1856
My Feedback: (49)
buck1856's Avatar
thanks rcjake,i kept it and refinished it in the origanal brown and antiqe cloth. i also have the floats which i did brown and creme. i purchased the center section so i can make it into a mono also.mines the e-3 stile antic. i also have the antic display prop, there twenty dollars from proctor.wish i new how to post a pic with this reply. thaanks.
Old 05-12-2003, 12:38 AM
RCJake-rcu
My Feedback: (7)
Hi,
Above you reply area, there is an area that says "for reply with full features and options, click here", click on the "CLick Here" and it will take you to another page where you can post a photo.
Try it and post a photo so we can see what your Antic looks like.
Jake
Old 05-12-2003, 07:08 PM
buck1856
My Feedback: (49)
buck1856's Avatar
ill have to try somthing else, says my files to big.
Old 05-14-2003, 01:38 PM
John Cole
Hi Jake!
Hmm, let`s fly on Sunday!! Or Saturday, or...?? Anytime. My Antic is ready to go.
John
Old 05-14-2003, 03:39 PM
RCJake-rcu
My Feedback: (7)
Hi John,
I am up for some Antic flying this Sunday. Maybe Buck1856 can make it also....
Old 05-14-2003, 05:01 PM
John Cole
Hey Jake,
Sunday it is! I`ll bring my Neiuport 11 also! WOO-HOOO!!
John
Old 05-14-2003, 06:24 PM
Mike Denest
Default Antic Weekend
How about some pictures so we can all envy you!
Old 05-14-2003, 06:32 PM
John Cole
Ok, bear with me.... I`ll see what I can do. Kinda new to posting pictures.
John
Old 05-14-2003, 06:35 PM
buck1856
My Feedback: (49)
buck1856's Avatar
hey guys, where are yopu at, where do you fly, your club feild where. whats your phone #s, ill call see what we can line up.my boys and i are restoring two vk neuport 17s and a vk sopwith camel. these are from the 70s like my antic. as a matter of fact they came from the same collection.hey, is there anyway to make a file smaller, my pic, to send it here.thanks buck
Old 05-14-2003, 06:38 PM
John Cole
Hi Buck,
We`re at the AMPS field, North Pheonix...43rd ave and Pinnacle Peak rd. I`m trying to follow Jakes` instructions to post, but no joy. I`ll keep tryin`!!!
John
Old 05-14-2003, 08:16 PM
Mike Denest
Default Heads Up!!
An Antic kit just hit eBay.
http://cgi.*********/ws/eBayISAPI.dl...category=19164
Old 05-14-2003, 08:19 PM
Mike Denest
Default Aw Rats!
My link got chopped. :stupid: :bananahea
Here is the item number to the Antic kit: 3131174598
Old 05-14-2003, 09:40 PM
Bud Faulkner
Bud Faulkner's Avatar
Default posting picture
Hi John,
When you bring your picture up do you have "image" on your toolbar? If so you can go there and resize...drop it to about 650 or 700 and it should go thru. I use irfanview for all my images...that way I can reduce file sizes also.
Bud
Old 05-14-2003, 09:47 PM
John Cole
Hi Bud,
Love them Antics!! I will be able to spend a little time this weekend learning how to post pics. It`s a little tricky because I`m using my work comp. Anyway, your Antic looks like it`s done? Or almost done? What motor? Details!
John
Old 05-14-2003, 10:31 PM
Bud Faulkner
Default antic
Believe it or not John that's my first antic I built about 1979 and sold after it was finished because I moved to New Orleans and had no space to take it along. I ran into a guy at our flea market this year who knows the man who bought it and told me he never flew it...just has it hanging up in his house still. I had an O.S.50 in it and had the muffler modified so the exhaust came out the bottom. I added mahogany veneer to the sides and the top and motor mount is painted with superpoxy. I'm still working on my bipe and since I have another antic mono I think i'll build those wings and I can switch back and forth. JENNY'S NEXT!!! Love those proctor kits!
Old 05-14-2003, 10:33 PM
RCJake-rcu
My Feedback: (7)
Yo John,
Sunday I will take a few digital photos of your Antic and post them here on Monday if you would like.
By the way...maybe we should have an Antic fly-in at the AMPS field sometime...
Smooth Landings,
Jake
